This is a short tutorial showing how to add links and photos to your posts.
This is a photo driven forum so if you don't want to see
on your thread then here is how you do it.
Lets start with the basics. In Fig 1.1 you see a screen shot of the post screen. #1 is the title box. When starting a new thread place the name you want for the thread here.
When looking at the standard post screen you will see the typical controls. Starting from the top left you have the font, the size of the font, the color of the font, similes, attachments, and forward and back buttons. The on the next row you have the font characteristics, Bold, Italicized, Under line. Then the alignment of the text, Left, Center, Right, and Justify. Then you have the numbered bullets, then the dot bullets. Next you have increase indent, and decrease indent.
All of these different buttons will place a html code in the post field. Then the text that you want modified goes in between the start code and finish code boxes which are signified by the "[" and "]" box ends.
Here is an example:
Lets say I want to change the font to "IMPACT". I would click on the drop down box for the font and click "IMPACT". This will place the proper code in the box like this {FONT="Impact"}{/FONT}. Now Type what you want in between the "]" after {FONT="Impact"} and before the "["{/FONT} like this "{FONT="Impact"}Test{/FONT}" This is the result
TEST
Please note that in order for this code to show up here I had to interchange the "[ and ]" for "{ and }"
This is true for what ever button you push. If you change the font and the color then you will have the codes stacked. The important part is to place you text between the ] and the [ boxes ends. In html code there is a box that tells the computer what to change followed by the item to be changed, followed by the closing box. The use of the / in the closing box tells the computer to stop using the specific changes. There for the easiest way to find the proper spot for your text is to look for the first [/ in the code.
Now Fig 1.2 is the Link code icon. There is two ways you can use this button.
First simply copy the link you want to post then click on the link button and paste the link into the provided box. See Fig. 1.3
This will result in your entire link url being posted as a click thru link. If your url is long that can make for a unsightly post. If you want to clean it up simply type something like the name of the subject of the link, then highlight the name and click on the link button, paste your link and hit ok.
Here is an example:
http://www.rctruckandconstruction.com
or the clean way.
The best RC Truck Forum
Both of these links will take you to the same place just one looks better than the other.
Now for posting photos. The board has the ability to upload photos for posting, however there are a few draw backs to doing this. First the board limits the size of the photo, not good for showing detail. Second the photos will not show up for someone browsing the site that is not logged in.
There are several site that host photo collections for free. Most of the members of the forum use
Photobucket. This how-to shows how to post photos from Photobucket.
In Fig 1.4 you will see the photo code button. In the event you are NOT using Photobucket then one way to post a photo or if you are posting a photo from a web site, copy the url for the photo then click on the photo button.
Enter the photo url into the pop-up box and click ok. Fig 1.5
Photobucket has made this process a LOT easier. When you have a Photobucket account you pictures will be placed in folders and al the photos will have posting url's and linking url's. See Fig 1.6
When you mouse over the photo you want a drop down box like you see in Fig 1.6 will appear and give you choices. In order to post a photo to your post here, one simply need to click on the "IMG Code" button then return to the post box and right click then click on "Paste" it's that simple everything else is done automatically for you. (Another great advantage to using Photobucket)
That's it in a nutshell. There are just a few more things about posting that you will need to know.
Under the post box you will see some choices Fig 1.10
Number 1 is the Misc. options section. Here the first box will be checked if you set your User CP to add your signature to all posts. If you do not set the User CP (Control Panel) for this then you will need to check this box if you want your signature included in the post. If you have the CP set for signatures and do not wish to have it on this post then uncheck the box.
Then box 2 is the subscription box. If you are posting to a thread that you don't really want an email for added post sent every day then click on the drop down box and chose "Do Not Subscribe". This is also a function that the default can be changed in your CP. Likewise if your CP is set not to automatically subscribe to threads you post to but you want to subscribe to this thread then click this drop down box and make the appropriate choice.
Next is the "Submit" button (3) And the "Preview" button (4). Before you submit the post click on the Preview button and make sure all looks good. You can also Preview the post as many times as you like while you are building the post just to make sure you have everything going how you want it.
That's all there is to it. I hope you find this helpful. If you have any questions please don't hesitate to PM me or any of the Moderators on the forum, or just about anyone for that matter, we are all willing to help.
