Thread: Classy Shak
Old 03-11-2012, 06:04 PM
Dreamweaver's Avatar
Weaver Of Dreams
Default Re: Classy Shak
Originally Posted by SWAGGER View Post
Dreamweaver, I used to build RC planes, many years ago. Things may have changed, but I used to get delron or PVC flexi tubes in RC plane shops. This was able to take a decent curve. I would run from cockpit to tail, down inside the fuselage. I would then get a thin flexi rod to feed through the tube and then you would have screw on "horns" hand screwed onto the ends of the rods and they would snap to the servo horn on one end and the control surface (rudder, aileron or elevator etc). I am sure that this would work for you and there are choices of design and finish on the horns available.
You can also make "hard" push rods. See video below, he uses the plastic horns I mentioned, you can also get alloy ones.
http://www.youtube.com/watch?v=3raUcsSjvhs
Thanks Swagger I'll see if I can find some and see if it will work.
Originally Posted by kaptain Jack View Post
I do a lot of R.C. boat building, at least half of them use flexi shaft for rudder steering, I'm sorry, I can't upload pictures,for some reason it never works from my computer,but if you have access to rc boats, you'll see right away how simple it is.
P.S. Love your build.
Thanks Kaptain Jack. I have no access to boats, I'll try and find something on youtube or something.
Originally Posted by Cossett View Post
Mike I just used a simple push rod made similar to what Swagger was talking about with a ball joint on the other end and a few other bends to get thought the turn table base plate and covered in black heat shrink connected to a micro servo...
Tracey got some pictures of what your talking about. The thing is to do it as I want it needs to be pretty flexible. I want the cable to come through the mounting base for the fifth wheel and then forward to the fifth wheel lock. Then I want it to go under the deck plate and up through the sleeper floor to the servo in the sleeper.
I was thinking hooking it to the bolt that the spring is on there so that the servo pulls to open.
Mike "DREAMWEAVER" Johnson
