Thread: Knight Krawler
Old 03-16-2012, 09:47 PM
TRUCKMAKER's Avatar
Default Re: Knight Krawler
Originally Posted by RCTech9 View Post
Nice Build, this will be awesome when finished!
Thank you for the compliment, I'm getting there slowly!
Originally Posted by grumpygrady View Post
[I am definitely learning as I go, I've changed the type and size of my solder 3 times. Still trying to figure out the best way to clean it up when I'm done, but that's what it's all about, if it came out perfect the first time it wouldn't be any fun. I'm using a small butane torch, .062, 60/40 rosin core solder]
on your solder try a 50/50 with no rosin ,and use a paste rosin and i think you will like it
if you are careful with the paste, the solder will only flow were you brush it on and that helps clean up ,
50/50 solder is the trick that the old timers used to fix radiators back when they were all metal
should find it in the plumbing section of your local hardware store
looking good so far
Grumpygrady have you seen 50/50 in a small diameter? What I didn't like about the stuff I had was the diameter was to big and it would deposit way more solder than I needed for the joint which made clean up much worse. I used some 1mm 60/40 from our electronics lab at work and it was great! No problems with the joints holding and you can get away with alot less heat. Thanks for the help and compliments, keep watching, more soldering to come!
Originally Posted by MoRockN View Post
One word, WOW. Super nice looking rig! Thanks for sharing.
Thanks MoRockN, lots more work to come, and I still got trailers to build yet!
I was just throwing some ideas around. More like thinking out loud, but I still like the router bit idea best, cause it uses power tools! Ha. I'm sure you'll get it looking good. You've gotten this far, and it's great.
LMAO You sound to much like me with the power tool thing, why do you think its taking me so long to start this part, I'm trying to figure out what power tools I have to make it go quicker, (I don't own a router) so i'm using my dremel with a coarse sanding drum to carve it into shape! Its actually working pretty well so far. Definitely keep throwing those ideas around, especially the power tool ones and thanks!
