Old 03-31-2012, 05:59 AM
Default Re: RC4WD excavator turret problem
Originally Posted by Jeremy View Post
Hi Guys,
It doesn't seem to be over-heating J.D and I'm not sure if they have a speed controller.. I did try doing a running test without turning the hydraulics on.. It was going strong for ~10 mins without showing signs of giving up.. I then turned the pump on and within 5 mins was at a stand still again..
Yep, it's a LIPO travis. Yep the battery is fully charged. How can I check if the battery is balanced?
Cheers
If you don't know if it is balanced then you can't know it is fully charged. What kind of charger are you using and does it have the ability to balance while it is charging?
If you can not answer some of these questions please take the time to go through the links I am providing and it should answer a lot of the questions you may or should have. This will also make your experience with this hobby a pleasant one.
Li Po maintenance
acronyms, abbreviations, and technical terms used in RC
When you go to the 2nd link you can click on the highlighted words for more in depth definitions.
If you have more questions don't hesitate to ask we are here to help and asking is a good way of learning.
Travis
