Thread: U BOLTS
Old 04-21-2012, 07:01 PM
dabears's Avatar
dabears dabears is offline
Default Re: U BOLTS
Originally Posted by ihbuilder View Post
macmasterCar
brass 3mm rod
standard brass rod you want .114"
little trick chuck your piece of rod in you drill (hand) , taper end slightly , dip in tapping fluid , and ( in low speed ) thread away to desired length and rev. drill .125 rod is to big , It'll werk but tends to slip in the drill chuck .
3.0000 mm = 0.1181
1/8" =.125
That helps me out. not sure if it helps Big John out. Not sure his question was ever answered as to if anyone knew where to buy pre made ones.
