Originally Posted by kaipi0070
Hello coligny,
first I drilled a small hole with a 0,1mm driller. Then I used this one to cut the material away. After that I used a very fine file to finish the hole. I used some of the yellow squre rear-lights from Tamiya and cut matching pieces out. Finally, I glued some SMD-Led´s with 5 minute-epoxy in the inside of the fender.
I hope, this helps!
Ok thanks, I will try that ASAP... I now have quite a stock of rectangular leds (2x5mm) to put to good use...
