Old 06-05-2012, 08:42 AM
omj86 omj86 is offline
omj86 is on a distinguished road
Default Re: I'm looking for suggestions on a low rpm, "realistic" gas engine.
Seems to be kinda hard to find a gas engine with lower rpm then 2500.
Is still need to be a small size so it will fit inside the Tamiya.
I guess I will try my first project with the Ford Aeromax, it will be good
to have the space avalibale in the hood and under the house, i guess it will be needed
I will have a engine that can fit in the hood, with the shaft facing backward, and have a fan in the front under the hood to cool it down.
How is it to have low and high gear on this?
I'm thinking lowgear on forward and rev, and allso a high gear on forward.
I know Tamiya have 3 gear speed controller on the el, but how is it to get this on the gas system?
How is the FS-30 4stroke to convert to gasoline or diesel?
How will the specs on the enignes be when convertet? Same RPM and tourqe?
Or will this change?
