Re: servo hook ups
Most use the left stick up and down which is throttle for the throttle and left stick side to side which is rudder for the shift. The right stick side to side which is aileron for the steering and right stick up and down is elevator which is used for the support legs if you are using the MFU. This is also the suggested setup for the MFU.
Now with a DX6I if the left stick is spring loaded then I would use the set up above. If the left stick is not spring loaded then I would switch the functions to the opposite sticks so your throttle will be spring loaded. As for putting the shift on one of the switches the DX6I really doesn't give you that option as all of the switches are only 2 pos and they wont allow you to have all three gears.
Set up with both sticks spring loaded.
THRO=THRO (ESC)
RUDD=SHIFT
AILE=STEERING
ELEV=SPARE OR SUPORT LEGS IF USING THE MFU
GEAR=SPARE
AUX 1=SPARE
Set up with only the right stick spring loaded.
THRO=SPARE OR SUPORT LEGS IF USING THE MFU
RUDD=STEERING
AILE=SHIFT
ELEV=THRO (ESC)
GEAR=SPARE
AUX 1=SPARE
Travis
