Thread: CAT 374D L
Old 08-27-2012, 10:15 AM
Default Re: CAT 374D L
Originally Posted by elliot330 View Post
Once again Ari, you've excelled yourself. It looks stunning - When you taking orders
Technical question from a dumb *** ( me )
Shouldn't the super structure sit on a thrust bearing or can the bearing you fitted take the heavy load from above, ie side load??
It's not a dumb question Elliot, I was thinking that myself but I think they will hold. If necesary I can attach bronce ring under the upper structure that will rotate over the ring gear. Those thrust bearings tends to be too high and they
