I'm done Dickin around with radios,& spendin a ton on them. THEN! They still don't do what I want. So did some diggin in my bone yard today.
& came up w/4 joysticks.
All's you need is a couple of these.
One of these.
Now here's the tricky part. If you place them just right against each other.It's almost like it's ment to be.
Then add tape!
Now be careful not to cover the important stuff w/the tape.
Man!! You won't believe how nice it works!
You can reach all 4 sticks at once!
Now when you Boys are done laughin,just remember this when you want to be able to feather control a bunch of different things on your build.
Ive spent a ton of doe on radios & can't non of them do what this does.
I used this today to set up my plow truck. Good thing I don't have another hand,I'de been touching my own stick,when I saw how good this worked!
Just thought I would share this CHEAP FIX!
FGD
