Old 11-17-2012, 07:12 AM
I have the pump on Aux2 (3pos) & set the sub trim way low so the middle position is like 20%. With the mix switch on, pump rpm will ramp up when the valve chs are activated. Due to the large size of the bl motor & pressure set to 25bar, have to have some rotation of the hyd pump all the time so the esc doesn't freeze (a squeal can be heard in some of the early vids of the JD850 b/c the pump speed got too low during delicate movement of the valves - emptying the bucket out across a full full trk to fill every corner without spilling). I could vary the pump rpm on the knob, but I like quick on/off of the switch.
I have two valve settings for the bucket & stick; one setting opens the valves fully without much stick movement for fast digging, the other setting it takes alot stick movement to open the valve for much finer control - like for changing buckets.
I have 3 different settings for the swing as well.
