Thread: Paint?
Old 02-06-2013, 01:24 PM
Goose19's Avatar
Goose19 Goose19 is offline
Goose19 is on a distinguished road
Default Re: Paint?
I painted my frame assembled with rattle can automotive "touch up" paint, er the same brand of primer. out works just fine, but you'll use a bit more paint trying to get all the angles when its together. I would recommend scuffing everything with a scotch bright pad or some 400 grit sandpaper, and priming it apart, assemble the frame and shoot some color. the only reason I did it that way was so all the hardware holding the frame together was painted aswell as the components. get yourself a write cost hanger or some solid wire to hang the frame off, so you can maneuver it around easily. good luck, post some pics when your done!
