Old 03-02-2013, 02:03 PM
CustomRCmodels's Avatar
Default Re: Driven front axle options?
Originally Posted by WhiteWolf McBride View Post
Travis: (or whomever has done this, like Willy & Joe)
What about the flanges on the axle casing? Do the casing halves that are being used have the flange/edge that overlaps (malke side?), or the other one? I ask as if it needs removal, it can be used as an alignment assist, right?
As for 'alignment', to assure that the 'throughput' pumpkin matches with the central piece, and the gear-mesh inside is ok, you just bore out the screw-holes (as you'll either have two bottoms with no access, or two tops with no thread to grab), and use long bolts and nuts instead, and it'll line up sufficiently well?
WhiteWolf
No cutting required . You just use the male housing (no lip ) part from a straight input/output rear axle and replace that with the non-input/output housing on the TLT-1 axle . Plain simple bolt on .
(Wild)-Willy
CustomRCmodels
