Old 03-17-2013, 12:42 PM
Default Re: S&M Trucking open for bizz nizz !!!
Mario, the lights are looking great. You did a fine job. I had asked about the voltage you intended to run your LEDs on because I noticed you had a resistor for each one, rather then a couple in series, with one resistor. I just assumed your voltage source was pretty low. Anything less then about 6 volts, and you kind of get stuck running the LEDs in parallel. Even on 7.2 volts, you really can't do more then 2 in series.
