Old 03-25-2013, 05:55 AM
JAMMER JAMMER is offline
Default Re: MORPOWER pump & valve
The case says DC 7.2 Volts 1500 RPM and the advertised pressure is 298.78 the gears are 3/8 inches in diameter and 7/16 inches tall and no relief valve. the drive gear has an O ring on the shaft on it and it is recessed in the case. the pick up is a hose connector with out the nut on it opening that up would help. I would say a bigger motor with more RPM and larger pick up and the pressure would go up. Ed
