Old 04-22-2013, 11:07 AM
A1 Dirt A1 Dirt is offline
A1 Dirt is on a distinguished road
Default Re: 4200XL Pump Motor Problem
No - This is a NEW replacement motor. It should have been ready to roll as received. I expected it to be OE (guess it was, it failed).
The motor shaft is smooth. I took the original motor apart and there are no notches or flat spots. I don't intend to take this one apart.
Depending on what I hear from RC4WD, I'll probably try knurled cove point set screws, then cone point, then cone point after drilling a detent.
As a last resort, I'll try a retaining compound. I called Loctite and the lady said that Loctite 290 is a wicking threadlock that can be used as a retaining compound. The only problem might be the shaft/housing tolerance - too tight, too loose, or just right.
There are a few warm, sunny days forecast and I'm anxious to get this digger outside in the dirt
