Thread: My first build
Old 04-22-2013, 06:45 PM
dirthalr's Avatar
dirthalr dirthalr is offline
dirthalr is on a distinguished road
Default Re: My first build
Originally Posted by JAMMER View Post
Jimmy were did you get the stainless elbows pre bent I bend mine but if I could buy them it would be easier? When you sleeve your pipes you could use stainless tubing K&S metals has the next size smaller that fits into the 1/2 inch pipe and if you silver solder them together when polished the joint is hardly noticeable. Ed
Ed,
I got the elbowsfrom www.microgroup.com they are 90° elbow; male-male. The part # is 90MM-8
I thought about sleeving with another tube, but I want alittle more meat to thread when I mounted to cab. A guy could always tig weld the elbows also.
