Originally Posted by wolfws6
Your build is AWSOME!!!!!! AMAZING!!!!!!!!! I'm lost for words, keep up the good work!
Thanks wolfws6!
Originally Posted by Claus
Beautiful work again Nathan. Like how you used the brass nuts to space the links and make everything line up like it should. The only thing you may want to consider for scale purposes, I think in the 1:1 world there would be a member running from one bolster to the other across the bottom but then again you don't need it.
I do love that scale driveshaft!
Thanks Craig!
I love the RC4WD driveshafts too!
Originally Posted by RCP57
I was wondering what was happening here....I thought you were suffering from no-postitis or something. Great job on the cross member and 4 links. When are we going to see this thing move around?
Thanks Reg! Not so much a case of no-postitis. It was more a case of re-makitis!
While it is a pain, sometimes, to go backwards with a build, the results are worth the effort, if you can do something better the second time around. This is a build as you go, kind of project.
