Old 09-18-2013, 01:58 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Help w/ new speed controller
Help,
Anyone have one of these small speed controllers? Is I have included a picture of what came in the package. No instructions. I have tried it with both an air band radio as well as surface. The function is the same for either radio.
When it powers on, with the trim in the center, the motor moves slowly one direction. You can move the stick in that direction and it speeds up, then go the other way and it reverses. BUT, then it will not got back the other way again.
It definately turns the motor both directions initially, but only at power up.
There are two of these in the photo, top and bottom view, and my note on the spec sheet is what I found on the circuit board.
It does NOT Appear to have an on board button or anything for programming. My search on the web has not u covered anything yet. It is supposed to be a 10A brushed motor ESC with reverse and brake.
Help! Even if your ESC is different, I'd try power on, throttle positions setup steps from anything, hoping for some lucky similar setup steps.
Jim
