Thread: Bob's M1070
Old 11-21-2013, 10:00 PM
kingbob kingbob is offline
Default Re: Bob's M1070 (maybe)
Just had a look at your build Szczerba, looks beefy!
Id just scratchbuild the body, its just flat panels so only need $10 worth of styrene sheet.
Im up-armouring mine as well, which actually makes the build easier.
I'm planning to use Integy axles, they make a driven front axle in 1/14 scale, so that makes life simple.
As for suspension, i'll be using a modified stock setup with Tamiya oil semi shocks. Also using Rock Crusher XT 1.55" tires, they're 94mm which is about right for 1/14 scale.
