Old 04-14-2015, 01:26 PM
JDH429's Avatar
JDH429 JDH429 is offline
Default Re: D10T Build
Originally Posted by mazdaparts View Post
Nice work. I would put the head of the track pins facing out, looks better to me anyways. Also what is the cost of the material you are using for the printer, and any idea of a finished cost?
ABS i use is about 30$ lbs. Maybe about 500.00 which is mostly electronics, not including the ripper parts, which is not designed yet.
Originally Posted by Trucker_Jo View Post
That is looking great!
Thank you
Its starting to look like something. Theres a delay in production due to some printer repairs going on. Hope to have the left side undercarriage finished this weekend.
Removable hood
Track rollers
Jason
Old 04-14-2015, 02:50 PM
What's its weight at now? Will it be all electric with linear actuators?
Using this Izzybilt dozer with twin Firgelli L12-30-100-12-S on the lift is working sweet! The blade lift is quick & powerful.
Old 04-14-2015, 03:03 PM
Very nice finish. Is it that nice straight from the printer?
Old 04-14-2015, 03:24 PM
JDH429's Avatar
Joe, each side of the undercarriage is almost 2 lbs, So im estimating the total built weight should be near 12-15 lbs. A tad over what i figured scale weight to be, 9.1 lbs..If i figured correctly.
This will be an all electric build. Ive got a set of 100mm L16 Firgellis to use on the blade, and a handful of L12s for experimenting with.
No, theres a a bit of post print sanding and treatment to get it looking somewhat smooth like it is. Thanks
Jason
Old 04-21-2015, 11:58 AM
JDH429's Avatar
Quick update.
Almost have all the parts finished. Slowely getting there. Just waiting on some hardware and will start assembling. Blade is filled with lead to give it some weight and blade tilt will be fixed. Ripper will be static until i get around to replacing some printed parts with metal and aquire the electronics to make it functional. For now it will just look cool.. hopefully.
Jason
Old 04-21-2015, 12:29 PM
Jepp, the whole project looks cool!
Old 04-21-2015, 02:18 PM
TRUCKMAKER's Avatar
Really nice Jason, Is all I keep thinking while following your progress is "I can't wait until the kit comes out" But........
Old 04-21-2015, 04:23 PM
JDH429's Avatar
Haha, Thanks. I have given it some thought. I may look more into that once the equipment im using is updated, which is in the works. Id be able to produce more parts at a quicker rate. Fingers are crossed. Thanks for following.
Jason
Old 04-22-2015, 12:24 AM
Trucker_Jo's Avatar
Default Re: 3D Printed D10T Build
Oh wow that is killer! I can't imagine putting in all of those C-clips is very fun, but I bet after doing a few you got a system down.
Jarrett
Old 04-22-2015, 02:22 AM
Lmackattack's Avatar
Great job with the 3d printing parts. This should be a cool dozer when finished.
MACK
"The Greatest Name in Trucks"
Old 04-22-2015, 10:03 AM
JAMMER JAMMER is offline
You are doing a great job keep up the good work. Ed
Old 04-22-2015, 08:17 PM
JDH429's Avatar
Thanks for the compliments. Got a little further today with testing and part fitment. Im digging the way its looking, but I realized after the first test of the track motors that they are lame (77 oz torque/51 RPM @ 12v= not good) and had to order another set with some better power. That means back to the drawing board to redesign the motor mounts and corresponding parts. Heres a few more pics of how its looking.
Jason
Old 04-22-2015, 09:59 PM
bigford's Avatar
bigford bigford is offline
that looks sick!!! post a pic with a coke can or something for size comparison
Old 04-23-2015, 09:25 PM
JDH429's Avatar
Thanks! Im sorry i couldnt do much better than this pic. Everything that could be painted was torn apart last night. If this helps, heres the blade next to a tall can.
Jason
Old 04-23-2015, 10:44 PM
Wow! I like it!
Old 04-24-2015, 12:14 AM
JoseFL10-4's Avatar
JoseFL10-4 JoseFL10-4 is offline
JoseFL10-4 is on a distinguished road
Wow, beatifull Great Job any idea a price Range after done..
Old 04-24-2015, 06:51 AM
JDH429's Avatar
Rough figure on cost with shipping
2 sabertooth 2x12-150.00, 2 Figelli L16 100mm actuators 150.00, 2 motors - 85.00, 100 track pins and e clips - 120.00, misc hardware - 35.00, ABS filament- 80.00, paint - 40.00... My time - priceless.
Total if I don't need anything else and not including radio gear & battery- 660.00.
Also wanted to add I think my estimated scale weight was way off, it should be like 100 lbs.. I think I can add enough weight inside to get it near 25 lbs easy, which should do the trick. It's heavier than you'd think already.
Jason
Old 04-24-2015, 08:47 AM
thebigo thebigo is offline
Very nice, and I like your Radio hang-up idea in the background.
David
Old 04-24-2015, 09:28 AM
Sounds about the same cost as my Bruder dozer conversions(same electronics basically) only the ABS cost is swapped with Aluminum and the track pins are K1 chain. Building this stuff isn't as cheap as some people imagine and the time involved to design and build the parts adds up. You are doing a fantastic job on it though and I can't wait to see it pushing dirt!
Old 04-25-2015, 02:07 PM
JDH429's Avatar
David
Thank you, I got that idea from RCP.
Your right, This is about as cheap as you can build a dozer from scratch? ...And mine has limited function, just blade up n down, and track movement. Thanks Reg.
Jason
