Old 02-08-2016, 10:52 PM
mcl fabrication mcl fabrication is offline
mcl fabrication is on a distinguished road
Post Gravel screener build
I've began working on a gravel sifting/screener. I don't have plans or specs or have ever seen one up close. I'm building with pictures, videos and any information I can find on company website.
I am also wrestling with the idea of having it on a stationary base or on a trailer for mobility.
Since this will be my second screener build I'm attempting to do something a bit more challenging. The first one was an attempt on making a bar separator and wound up with a vibrating screen.
So here is what I have so far. And PLEASE If you have any ideas or have made one or have up close pictures please don't be shy and reply.http://
Old 02-09-2016, 08:13 AM
pumptech's Avatar
pumptech pumptech is offline
pumptech is on a distinguished road
Default Re: Gravel screener build
Looks great MCL ,looks like it going to work great ,bet it took some time to cut out the pvc ,how did you attach the expanded metal to the inside
keep up the great work
Old 02-09-2016, 12:06 PM
Thanks PUMPTECH. I drilled pilot holes and cut the PVC with a jig saw, I used a downward facing blade so I can see the lines as I cut. It was doing the measurement and making straight lines on a round object that took the most time.
I will be posting some pics of the inside and show how I got the screens fastened in.
Old 02-09-2016, 10:10 PM
jeffgp jeffgp is offline
jeffgp is on a distinguished road
nice start to it .... cant wait to see more finished pictures
Old 02-10-2016, 11:24 AM
Stuff's Avatar
Stuff Stuff is offline
seeing that pipe gives me an idea. in the water well drilling industry they have machines to slot casing. I wonder if I can get one of the guys to take some 7 or 8" casing and cut 4 large "slot" windows in the section.... might work, might not.... hmm.
my YouTube is -
Subscribe!!
My Facebook -
Old 02-10-2016, 12:40 PM
From what info I've been getting any pipe will work. Just remember the heavier the pipe the stronger there geared motor has to be that is turning it.
Ideally I was getting that a semi truck exhaust pipe would be best, on that thought since BIGFORD is the only trucker I know in my reach I'm going to ask him if he has any old exhaust pipe around him. might get lucky.
Old 02-10-2016, 01:00 PM
rccrazy523 rccrazy523 is offline
rccrazy523 is on a distinguished road
Hi if you need pipe let me know I have to my availability just about any size pipe you want
Old 02-10-2016, 01:05 PM
Northern Farmer's Avatar
Just watched this video and thought of your build!
http://youtu.be/_q9qrSOt09E
Old 02-10-2016, 01:13 PM
I think a lot of guys are using air and oil filter screens for trommels. Works well and very cheap if you know a place to get them used.
Old 02-10-2016, 03:21 PM
That's a good idea
Old 02-10-2016, 05:16 PM
bigford's Avatar
bigford bigford is offline
no pipe and we just tossed 4 w900 air filters out. but im in brooklyn
every day i can meet up with rccrazy and grab the pipe for you..
Old 02-10-2016, 09:14 PM
Thanks man If you have any 5 or 6 inch pipe close to 30 inches long would be dynamite, any old air filter would be good as well good for the screen.
Old 02-10-2016, 09:17 PM
Thanks BIGFORD for looking out. I appreciate what your doing.
Old 02-10-2016, 09:26 PM
I have that size pipe Pvc or steel ? And I will get you the mesh from the air cleaners no problem
Old 02-10-2016, 10:05 PM
I would say steel, it should have a more authentic look some what when I'm done. OH the thinner the pipe the better. Thanks
Old 02-11-2016, 06:50 AM
This is the outer mesh from an air cleaner that I use in my 275 MF tractor, measures close to 5 inches diameter. The ends are made from oak.
The tube in the background I can't remember where I got that from, the diameter a bit smaller, closer to 4 inches. The holes are much too small for screening dirt, be a good tube for sifting pit run to get sandblast sand quality.
Old 02-11-2016, 06:24 PM
Here are some more photo's of the project. I have a 4" PVC pipe with cut out sections for the screens. Two 4" reducing couplings and a 4" end cap. And three different size screens.
Old 02-11-2016, 06:31 PM
Here I'm getting the center of the end cap. I also use those lines for a reference when cutting out the ports for the large debris. The center of the cap will hold the shaft for turning.
http://
Old 02-11-2016, 06:33 PM
Now to cut the ports on the end cap with the reducing coupling. I drilled pilot holes to make it easier.
Old 02-11-2016, 06:35 PM
I use Tamiya screws and nuts to hold them together.
http://
