Old 06-08-2015, 06:41 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
Default Re: More than just a thought ...
Yes just fine. Had it down at the Frankfort toy show a month or so ago. Did just fine. Swapped out the swing motor for a slower unit. Designing the boon parts right now.
Old 06-08-2015, 07:34 PM
TRUCKMAKER's Avatar
Wow thought we were going to have to put an APB out you!
Old 06-11-2015, 08:39 PM
Izzy's Avatar
Backyard enginier
Working serious overtime 10's and 12's and some Saturdays
But also working on the boom design.
Old 08-07-2015, 09:14 PM
mtdriver's Avatar
mtdriver mtdriver is offline
mtdriver is on a distinguished road
Izzy, ive been out of the game a while. And here i come back and this was one of the first projects i check out. And it looks great! Ill be at Indy this year, hope to see ya in person!
Old 01-03-2016, 03:36 PM
JD Transport JD Transport is offline
JD Transport is on a distinguished road
What news Izzy on this lovely mobile crane? Happy NY to all. JD.
Old 01-30-2016, 03:39 PM
Izzy's Avatar
Backyard enginier
Hmmm, been hibernating most of fall winter. Have had the tubing and sleeves for the boom. Waiting on cable spools. Hydraulics made me water to hit it with a hammer so I gave it a rest.
It will be at the Lebanon show and of course Indy
Lebanon show link
http://www.rctruckandconstruction.co...ad.php?t=11044
Old 02-21-2016, 04:52 PM
Izzy's Avatar
Backyard enginier
Been a long winter with many distractiond, but with the help of a good couple friends getting the bug to build again.
So if some of this is repetitive - appologies. But this is where I am at.
Lift cylinders, another learning curve here. Thought that sir fittings were air tight right? Not so much. Have to replace the fittings, they leak.
Over all shot, not bad. Going to use an idea from a fellow member on the wheel inserts. Stock foam just way too soft and machine way too heavy. Craft foam sheets is where I am headed.
Boom sections -just finished bolting up. Need spools - friends are priceless.
Had to have the caps remade since I designed them too small the first time round.
Old 02-21-2016, 05:34 PM
TRUCKMAKER's Avatar
Looking good Izzy, hope to see it in any form at Lebanon.
Old 02-21-2016, 06:53 PM
Izzy's Avatar
Backyard enginier
She will be at Lebanon, working boom is the goal.
Old 03-06-2016, 06:56 PM
Izzy's Avatar
Backyard enginier
Mocked up the boom today. Good friends with talents are hard to find. Thanks lynn
Old 03-06-2016, 07:01 PM
kerst's Avatar
kerst kerst is offline
Very nice!
Kerst
Old 03-09-2016, 09:53 PM
crawler07 crawler07 is offline
crawler07 is on a distinguished road
Oh my gosh what a monster!!!!! Every part is well thought out and perfectly executed I cant wait to see this thing swinging a bridge section into place.
Old 03-10-2016, 09:58 PM
Izzy's Avatar
Backyard enginier
Pretty happy myself. Took a break from it and had parts made, so cleaning up some loose ends.
Izzy
Old 03-10-2016, 11:21 PM
Northern Farmer's Avatar
Thumbs up Re: More than just a thought ...
Great project Izzy this one must take up a whole shelf
Old 03-11-2016, 12:27 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Impressive!!! Knowing how big the front sheeves are, gives me some idea of the overall size. Can't wait to see it!
LYNN
Old 03-12-2016, 09:20 AM
Izzy's Avatar
Backyard enginier
Yes whole shelf and whole bench. Part of the reason why I bought a utility trailer for my rc's. She won't fit in the Envoy.
Old 03-12-2016, 12:26 PM
Smiley's Avatar
Smiley Smiley is offline
Smiley is on a distinguished road
If it won't fit in it then strap it down on the top of it lol
Old 03-12-2016, 05:58 PM
FabOne's Avatar
FabOne FabOne is offline
One AWESOME build Chris! It keeps getting better. Anxious to see it at Lebanon.
-Terry
FabOne
NW Ohio
Old 03-20-2016, 08:10 AM
Izzy's Avatar
Backyard enginier
After mocking up the boom I set her on her feet. Wow, almost had rims string on the bench the tires were so squished. And that's with the stock foams.
So been asking around - see previous posts.
So This is what i did
Dissassembly,
Donor wheels with hard foam inserts
Slice part of the carcass off
Wrap 2 side by side in craft foam sheet - test fitted strip in side tire to get correct size. Had tried tires along but did not fill inside space.
And then squish it all inside. Good thing these tires are soft.
Then used clamps to clamp together.
Old 03-20-2016, 08:12 AM
Izzy's Avatar
Backyard enginier
After having had bolts fall out of these rims, I drilled out the 2.5 mm holes and put in 3mm screws, thread the outer shell to keep the stud look.
