#121
Added the final angle sensor that reads the angle of the boom. This sensor is the same as the previous two, except that it's mounted a bit differently and it has no cover.
With this sensor in place it's finally possible to run the excavator without risking to break it. :-) If I have time later I'll try to read the rest of the positions and angles with encoders for the swing and tracks, and an IMU (BNO055) + GPS for the house. ![]() ![]() ![]() |
#122
Running lines along the arm.
I need to run the power to the bucket motor and wires for the bucket and stick angle sensors along the arm. Also, I want to attach some auxiliary lines that can be used for various attachments later. I ran totally overboard with the auxiliary lines. I've added: - 2 x 2 x 0.75mm2 power line with XT-60 connector (one on each side) - 2 x USB cable (one on each side) The power lines can run about 10A each and can be used for driving motors, lights, etc. The USB cables can be used both as USB cables and also as just normal wire that can be used for driving servos or sending back sensor data. Each USB cable has two wires that can run 2A and two signal wires that can't really run any current, but can be used for signals, like the servo position (the white wire) or sensor output. So the USB cable doubles as a servo cable that can control two servos, just normal power lines (2A) or sensor wires. With a small adapter from USB to Futaba connectors, it will be easy to hook up servos. Some examples of what can be attached: - Quick coupler (using just one power line and that stops on a set current limit) - Impact hammer (one power line) - Drill - Saw (garden timmer, angle grinder, etc) - Light - Any USB device, like a web camera, a 3D depth camera like the Kinect, a desktop rocket launcher, a 32 channel servo driver, etc, etc. USB cables have very varying current capabilities. The cable I'm using here has very thick power lines and the thickness and stiffness also helps to give a visual appearance more similar to hydraulic lines. The the three-wire sensor cable, two-wire power cable and the USB cable: ![]() I've 3D-printed three different types of clamps to hold down the wires along the arm. The screws are 2.6mm x 8mm self-tapping screws. ![]() And a terminal at the stick: ![]() ![]() And it all attaches to the arm in this way: ![]() ![]() ![]() ![]() ![]() ![]() |
#123
It's always a question where to put the required RC-components on a machine. I'm talking about things like the on/off switch, charge connector, etc. I want them accessible, but not visible.
On this machine, they could all go underneath, but I'm thinking that there might be a lot of dust, dirt, braches, leaves, etc there, and also it's not that accessible on the underside. So on this model, I opted to put them on top, but conceal them under a lid. I'm mimicking the engine lid from the original: ![]() And then underneath the lid, the control panel is located. It has: - The on/off switch - A battery voltage meter - A sound volume dial The charge connectors are just a standard XT60 and a balancing connector that are accessible under the lid, not attached to the control panel. ![]() ![]() The control panel stand also serves as the mount for the audio amplifier. The amplifier is a 2x50w D-class amplifier. The volume control is a stereo logarithmic pot - A1k. Ebay links: - Amplifier: http://www.ebay.com/itm/272163830096 - Volume control: http://www.ebay.com/itm/331883285534 - Voume cap: http://www.ebay.com/itm/221309764371 - Voltage meter: http://www.ebay.com/itm/201546863361 ![]() ![]() ![]() ![]() ![]() |
#124
Beautiful form and fit, just outstanding !!
#125
When you say charge connector...are you planning on charging a lipo in your model?
#126
I know of the general rule not to charge inside the model, but I charge very lightly (only 1A out of the 1C 4.5A normal charge current) and also the compartment where the battery lies is well ventilated so heat should not build. But of course, time will tell. I guess when you charge inside the model, you should assume that everything can catch fire, and place the model in such a way that it would not burn down your house or garage if that happens. Best regards, Stein :-) |
#127
Test digging gravel and also testing the audio and the smoke generator. The engine sound will be replaced with an excavator sound and both the sound and the smoke will be made to adjust according to the power output of the machine when it's working.
![]() https://youtu.be/MyzdAea7NRI |
#128
The smoke generator was the surprise that I promised earlier :-)
It works quite well as you can see on the video above. I mounted it so that the output is at the same location as the exhaust on the original CAT 390 F. ![]() Ebay link: - http://www.ebay.com/itm/112036055150 I have the 12V, "standard NON ESC" version with red color. I control the variable output with the first channel on the fourth motor controller. ![]() ![]() |
#129
Great idea using the smoke machine. The RC drift guys have been trying to use smoke generators for a while now with mixed results. I think it should work well for your application though since it doesn't require the volume of smoke that a car needs.
-Jeff To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#130
Lately I've been working on designing and printing the house of the excavator. I want:
- To have quick access to the on/off switch, voltage meter and the sound volume control - To have easy access to all the electronics inside the excavator house. For the first item, I designed the lid above the control panel: ![]() ![]() So that makes it easy to quickly turn the machine on/off or to change the sound volume. But for getting access to everything, i wanted to be able to remove as much of the house as possible in just one piece. So I designed most of the body to be just one big piece that can removed by unscrewing four thumb screws from below. The exception is the cab and the thing on the front on the other side (whatever it's called, anyone knows? :-) ). This gives very good access to everything that's mounted on the upper structure base plate: ![]() ![]() ![]() ![]() ![]() ![]() ![]() The body attaches to the base plate with four thumb screws, one in each corner: ![]() This body is much to big for my 3D printer, so I had to break it up into nine individual parts. And even each of them was almost to big for my machine. ![]() ![]() The printing time for each of these is between 10-15 hours, so that means there's more than 100 hours of continuous printing in this body. ![]() I'll add some photos of the parts and how they are connected together shortly. Best regards, Stein :-) |
#131
Great work, loving the details. Dont know how good your printer is, but if I were you, I would remove this grills, and print them separatly.
#132
Hi Doggy!
Yes, I could probably get them even nicer if they were separate pieces. But now it's already done and also it's less pieces to handle when it's in one part. The number of parts on this machine is growing rapidly.. :-) Best regards, Stein :-) |
#133
I experimented a bit to figure out the smallest mesh size I could print without supports on my 3D printer. On the original, the meshes in the doors and in the platform look like this:
![]() ![]() I can't make that fine lines easily, so I made the meshes a bit coarser. On the platform it's supposed to be two rows of six holes, but on this model it is two rows of three. At a distance it all looks quite similar, though. The mesh lines are 0.8mm thick This is because the print head nozzle is 0.4mm wide and I need two lines beside each other to print the mesh nicely without supports on my machine. The layer height is 0.2mm and thus there are 4 layers in the vertical direction to make up the 0.8mm mesh line size. Also, the mesh had to be coarse enough to allow air to flow through, as the air is needed for the cooling of the motor controllers on the inside. Detail images: ![]() ![]() The parts: Counterweight: ![]() Doors: ![]() Smoker air intake and smoker exhaust: ![]() Lid and temporary hinge pin mechanism: ![]() Tanks: ![]() Steps: (this is printed in yellow and then painted partially black afterwards) ![]() |
#134
Your prints are coming out really nice. What 3D printer do you use? Are you able to change your nozzle size for printing some finer details?
#135
Hi RexRacer19!
This is the machine I have: - MakerBot Replicator 2X It's a very standard configuration, very similar to most all 3D printers sold today. I think it is possible to get this quality with most all current printers. If you don't, then have a look at this very good print-quality-troubleshooting page: - https://www.simplify3d.com/support/p...oubleshooting/ But mine is quite an old 3D printer. I think these days, you can get better offers. The only important thing is that you can print ABS, because it's so much tougher than PLA (less brittle). And then you need a heated build plate for ABS printing. Maybe one of these could do the job: - Ultimaker 2 - Zortrax M200 Pro - FlashForge Creator Pro I've not tried any of them, but I've heard some good things about them and the specs look ok. There's probably lots of reviews on youtube. I think most 3D printers that work with filament have 0.4mm nozzles. You can change to 0.2mm to get finer detail, but that will also make the print take a lot longer (4 times as long if you print the same object with the same wall thicknesses, and if the print time was 10 hours, then the new print time is 40 hours..). Best regards, Stein :-) Last edited by SteinHDan; 08-12-2016 at 03:15 PM. |
#136
Stein,
Thanks for the detailed reply. That is a good printer that you have. My first printer was actually the FlashForge Creator Pro, that I purchased to use at the company that I worked for. It worked very well. I no longer work for that company, but since bought a printer for home use. It is a Makerfarm Pegasus 10". It does a nice job, and has a large build volume. The hot end is a E3D V6, and I have that on a E3D Titan extruder. It is a very customizable platform, and easy to upgrade. It all runs on Simplify 3D. I will have to post up some details and pics sometime in my 963K build thread. -Jeff
#137
I'm looking forward to that, Jeff!
Stein :-) |
#138
I don't like doing non-reversible operations like gluing, painting and welding, because it's then a lot a work to make small adjustments to parts. And when doing prototyping like this, you make small changes all the time. I think I've had the machine built completely up and down around five times now..
Anyways, sometimes you need to do those types of operations anyway, either because it's the only way or I'm not able to think of any other way.. ;-) I've glued the counterweight pieces together now. First there are three 75mm M3 threaded rods. They don't screw into anything, they are just there to align the pieces and give more strength. Then the two pieces slide together: ![]() ![]() ![]() I think the best glue to use for a certain type of plastic is... more of that same plastic! Dissolved in acetone. This approach works very well with ABS. For this model, I've just cut the yellow 3D-printer filament into very small pieces and put them into a glass jar. Then add acetone and let dissolve for a couple of days (depends on the size of the pieces). ![]() ![]() I've also glued in the stainless steel M4 nuts that hold the body to the base plate with the thumb screws. One in each corner: ![]() Just a tiny amount of glue is needed here. We just don't want the nuts to come loose when the thumb screws are not holding them in place. ![]() ![]() Ebay link: - Thumb screw - 10pcs M4 x 15mm |
#139
The body goes together by using eight M3 threaded rods, four self-tapping screws and two M3 machine screws.
First M3 nuts are inserted into slots in the counterweight parts: ![]() ![]() Then the threaded rods are screwed into the nuts: ![]() The rear doors slide onto the threaded rods, and are attached with an additional two M3 20mm long bolts: ![]() ![]() ![]() The front doors also slide onto the threaded rods. They are attached to each other in the middle by three M3 bolts and locking nuts. This attachment is the bridge that holds any weight on top of the house body. ![]() ![]() Finally the tanks and the steps slide onto the threaded rods: ![]() For these two parts, there are four additional self-tapping screws that attach the tanks and steps to the front doors: ![]() At the end of the threaded rods, there are M3 nuts countersunk into the end of the front parts. Since they are completely inside the part, a socket screw driver is needed to fasten them: ![]() ![]() |
#140
I made a somewhat improved snap-in hinge pin assembly. I should have used some longer bolts, but I didn't find any.
The assembly consists of two M3 20mm bolts, one compression spring and an aluminum tube to hold it straight: ![]() ![]() The hinge pins are then snapping into the holes in the sides of the lid opening in the body: ![]() |
