#241
Looks great Steve!! On that sabertoith, I found out my problem, when it would find a false neutral and start running when sticks were centered,,, from what I could understand they have an inbuilt logic that finds neutral when started and is constantly comparing forward,neutral, and reverse. If you start going forward right away and keep going sometimes it will sense that as the neutral. I may not be explaining it well but the short version is if you guys use sabertoith and it creeps or runs when it shouldn't be. Stop disconnect power, re power up and let sit in neutral fro a while then move forward /backward and let sit a couple seconds in neutral. Usually not a problem with most models but dozers often go one direction for a while. Basically if you power up start going forward for longer than it sat in neutral it may think that is the neutral position and logically adjust accordingly. ?!?? And for me it seems to be working. Don't know if it is a certain timeframe of batches built or all?
And take my input for what it's worth, not much ![]() Can't wait to see this in person Steve. I'll stay on the other end of the dirt pile with the lightweight d11!!!! Still envious of track links!!! Wonder if they wil fit the d11? Ever see a td40 on blocks after someone swiped the tracks??! ![]()
#242
IT"S POSSESSED ! KILL DOZER!!!!
#243
#244
Just went thru this whole build thread, amazing work man! That drive system and the tracks have an amazing amount of engineering and machining time into them. I love it, well done
#245
Ha , yea kill Dozer may be a good name for it as in killing planet gears that are not hardened
#246
Steve, thats a hefty looking machine. Original idea too, not the same old Cat thing thats getting over done these days. Maybe you can lose the skidsteer and run this bad boy instead.
Jason |
#247
Thank you Jason
![]() ![]() My Da, the ME, came up yesterday morning and we discussed the planetary issue . I just got to get as big of gears as I can get in the hub . Hopefully I can get the parts ordered tomorrow from HPC gears without too much trouble .
#248
I hope so too, and it works out for you. I enjoy the challenge of the build as much as the next guy, but sometimes its nice to just get it running the way you want to without getting to discouraged. Its always worth it, and this one definitely will be.
Jason |
#249
Looking good Steve, so what's next?
SHANE... Member of the Central Plains Mini Truckers.. |
#250
Finish house addition/start on new shop and work on getting my excavators done .
#251
Long over do update pics of the new planetaries . I'm trying flicker
#252
Nice work Steve
Thread Tools | |
Display Modes | |
