#2061
#2062
#2063
At least you made it through the guard leg running tree rats !
#2064
Lol!!! I think most of them that wow last years " Los autos de chicken " race are holed up in the attic till spring.
#2065
![]() ![]() The new chains on the dozer work great,,, but then one problem fixed another popes up. Had to make new sprockets also. ![]() I did get some "work" on the new mine claim project. ![]() ![]() ![]() ![]()
#2066
Did you take a pic of new vs old sprockets together?
Was it the pitch that changed or the old sprockets worn that much?
#2067
I'll get a couple pics tomorrow, I changed the relief angle on the new one to a bit tighter to "hold" a bit better. But after I cut them and physically looked at them I realized it may have been too tight but they work and don't bind. Only will get looser as time goes
#2068
Pitch was same, I think when I had dozer apart I placed the left sprocket on right side and vise versa. I know it doesn't matter but with the wear I think when the dozer backs up it is more prone to skipping. (Design geometry of high sprocket) and more wear from forward motion. Combined to enable them to skip quite a bit when it was backing up. That's what got my attention. At cabin fever it was skipping some but I just figured I had loaded some dirt in tracks. They were the original sprockets. They have seen three bushing replacements,( track pins worn out) and now a new set of tracks) so how many years she is, 3-4? And has pushed a lot of dirt. Road wheels had bushing replaced, along with new shafts, and small wheels were completely shot that I recently replaced them with steel ones. . I doubt it will happen (probably a new dozer first) but if I get the time and ambition I would like to make track links, link pins, and sprockets from steel. But now I should be good to go for anothe year or two. I imagine before long the motors are going to need replaced. They are worm reduction and only have one side of the final output shaft that has a bushing on it. Frankly I'm really surprised they are still going strong!! As I speak I am now thinking of ordering new ones,,,, Murphy's law!?!??!! Lol!!
#2069
![]() ![]() ![]() ![]() Old ones didn't have as much height on top of teeth and more taper angle. But they were worn a bit. The new ones are also side tapered towards the top of teeth. I hope that will help pierce any dirt that gets in links verses them being more flat packing it in there. Didn't have much of a problem before unless I would have a lot of dirt roll into the tracks from side pushing or sharp turns. And went up to the local cat dealer today for service on some equipment and brought the d11 with, told them I needed work on a d11 and had it in the back of my pick up truck,,,yeah, it went quiet,,, then a couple of them came out to look. Before long they pretty much shut down and had about 30 people out checking it out. I think they enjoyed seeing it and said to bring it and anything else up again. And it's not often these guys come to the dealership for trade or service but I got to see an older d11 up close. I wish I would have taken a pic of blade. ![]() ![]() ![]() The pictures don't do it any justice, I'm 6' and was eyelevel with lower part of drive sprocket.
#2070
Would have been neat to see a pic of all those guys looking at your dozer
#2071
I bet the D11 in my pickup reaction was priceless!
It's awesome they let you check out the real one, that's massive.
#2072
"And went up to the local cat dealer today for service on some equipment and brought the d11 with, told them I needed work on a d11 and had it in the back of my pick up truck,,,yeah, it went quiet,,, then a couple of them came out to look. Before long they pretty much shut down and had about 30 people out checking it out. I think they enjoyed seeing it and said to bring it and anything else up again "
Yea, same thing happened when I took the D6 with me to my dealer to pick up filters for my 303 excavator
#2073
![]() ![]() ![]() ![]() Spent a lot of time with the ripper, the clumps of grass are not easy to dig with the blade. Once loosened with the ripper they came up. Stripping all the grass off to get to the good stuff, dirt!! I wasn't sure what the dirt would be like in this location but it looks to be better than the topsoil I had been importing from before. More small stones but good so far ![]()
#2074
http://youtu.be/kSZGJ2QE7BY
Here is a video. I switched to a different way to upload video, it only took 5min to upload but quality is poor. I'm still trying to figure it out ![]() I did bring the tractor over and tilled up the grass. Only one pas with the tiller to just break the sod up. It is still tough to push. Chunks of grass are sometimes harder to push than rock. And the tracks don't slip but hit some small rock every once in a while when it appears to skip. New tracks and sprockets were hiding up well, dirt was pushed into tracks and still didn't foul them. Happy so far.
#2075
![]() ![]() If I get some time tomorrow I'm going to try and get some video of the haul truck and count how many scoops it takes to load. When I built this I knew it would be a process to load it. I like running the excavator but it has now become fun to run the haul truck too. I may need to rethink the lay out and create a longer haul road. ![]()
#2076
Awesome pictures and video. Your equipment are beasts.
#2077
Video quality not too bad, you're outside with lots of light, did you save vid on Ipad "for email" setting?
If you had yourself a real track hoe you wouldn't feel the need to cheat with life size equipment ![]() Found Mr Nutters, he's enjoying ice cream cones down south ![]() https://s.theweathernetwork.com/vide...312993038001_2
#2078
The CAT is can push a good pile of material, cool video.
Greg |
#2079
![]() And yes I really should start thinking about a new hoe,,, a lot of things are starting to wear, this will be the third swing motor, still works but a lot of play, track motors just don't have the strength. Or some more modifications. Probably go with that when something completely fails. And yes a little extra help was outsourced for the ground cover removal to start stripping the topsoil down to concrete wall grade from the old silo. Really the only reason I did use the tiller was to save some wear n tear on the lil' company assets. I did use the ripper to rip a 6x6' area. Sod ripping is pretty tough on the dozer ![]() ![]() And I wish I would have had taken more videos when we had mr nutters in the house. Thanks for sharing joe ![]()
#2080
A little rusty with the controls and a little more slop in the swing but some more hoe digging. This is stripping the grass and topsoil from around the old silo base. It's kind of like a strip mine because a layer or grass, a layer of decent dirt, then a layer of shale. I'm not sure how deep the stone and shale is. The dozer needs to come in a do some more ripping. I'm trying to get down to the bottom of the concrete along the walls. And no more sub contracting
![]() http://youtu.be/VIVwoph5Lzg
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
