Old 02-12-2017, 12:54 PM
roadranger's Avatar
roadranger roadranger is offline
White Line Fever
roadranger is on a distinguished road
Default Chinese knock off sound board
I've bought a Chinese knockoff Servonaut sound board from wbtcar (Lesu, I think). No instructions came with it, just a wiring diagram. I've got it wired in to the truck as shown, the green light on the board lights up, but no sound.
While installing it, I noticed a programming plug labeled "remove for set up", so I tried that way, but still no sound.
Does anyone know the setup procedure for these boards? HELP!
WILDCAT T&C
Jim B.
Colorado Springs
Old 02-12-2017, 01:42 PM
roadranger's Avatar
White Line Fever
Default Re: Chinese knock off sound board
Here's a pic of the board - anybody use one of these? How do you set it up?
WILDCAT T&C
Jim B.
Colorado Springs
Old 02-12-2017, 04:33 PM
blitzk's Avatar
blitzk blitzk is offline
blitzk is on a distinguished road
Try this.
http://rctruckandconstruction.com/sh...ad.php?t=10868
Old 02-13-2017, 12:39 PM
roadranger's Avatar
White Line Fever
Thanks for the help, blitzk!
Found my problem, I was trying to run the sound from the throttle stick without going thru the start up procedure on the other control stick. NOwhere is this explained anywhere.
Here's what I mean;
https://www.youtube.com/watch?v=E-3ADvABQks
Good to know on blitz's link there are 4 other functions that can be accessed for setup.
Thanks!
WILDCAT T&C
Jim B.
Colorado Springs
Old 01-18-2021, 01:52 AM
Beetlemankurt Beetlemankurt is offline
Beetlemankurt is on a distinguished road
Hi all, new here and have a question for you. I bought one of these boards and put it in my Tamiya Scania which for all intents and purposes, works well. I set it up as per the standard instructions and have my truck running with a Spektrum DX6 transmitter.
My question is, can you adjust the matching of the revs to the position of the throttle stick somehow? As it is, it sounds good but I’d kinda like it to rev higher earlier in the throttle stick position....
Sorry if this is a bit of a newb question. I look forward to your guidance.
Thanks very much
Kurt
Old 01-18-2021, 04:16 PM
This thread is kind of old...might get better results if you start a new one....
Old 01-19-2021, 03:33 AM
Thanks Jerry56, will do.
Cheers
Kurt
