Old 04-11-2011, 06:00 PM
Car5858's Avatar
Car5858 Car5858 is offline
Default Oshkosh Het M1070, M1000
I started this build last week. Spent the last 6 months designing it in my free time. The first version was a wood replica, (avatar pic) some engine details and cab interior.
Old 04-11-2011, 06:19 PM
Car5858's Avatar
Default Re: Oshkosh Het M1070, M1000
This is what the truck was designed from. I also found that blueprints.com is a good starting point for basic drawings. I searched the web and found Oshkosh site, some of their brochures have the specks for the truck and sometimes include an orthograph view of the truck. To bad they removed the Het that I am modeling from the site.
First things first, the design of the tractor is 22.5 inches long. This will be a 1/16 scale build due to having the tank for it already.
Been gathering parts, so far I have 2 tlt-1 axels for the front and rear steering. I have 2 intermediate axles, not happy with the width to wide with tires mounted.
My father has my lathe at his place and will be turning the hubs for me. I havent decided on the tires so far, I like the rockcrusher from rc4wd, but the OD is 3.55" ,y model calls for 3.3", I think it will be close.
I am planning on a Tamiya 3 spd and maybe an rc4wd 2speed as a transfer case.
I did get the frame put togather, and the tranny in position. Started on the cab yesterday. This is my first try at styrene, so I hope you are not as critical as I am myself. I have the floor positioned, then it was late and had to get ready for the school thing.
Old 04-11-2011, 06:39 PM
DieselKid's Avatar
That's true craftsmanship right there, very cool use of wood!
Nice work,
-Alex
Old 04-11-2011, 07:18 PM
russisloud's Avatar
your wood models are amazing!
Old 04-11-2011, 10:03 PM
Car5858's Avatar
Thanks everybody, saw a problem with the frame after I posted. The redesign is finished now I just have to make some more parts.
Old 04-11-2011, 10:17 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Great looking model! I think you have the skills to make an exceptional rc model M1000. If you can make one out of wood, plastic and metal should be no problem
LYNN
Old 04-11-2011, 10:19 PM
Car5858's Avatar
I will be giving it a try, may take awhile as I learn new things and remember some things that I have forgotten.
Old 04-11-2011, 10:55 PM
Hey Carl, check out the big lorry blog site and do a search, I think there's more picture's in archive's http://www.roadtransport.com/cgi-bin...ncludeBlogs=22
Later, Neil#2 aka doodlebug.
Old 04-12-2011, 01:09 AM
Car5858's Avatar
That is a cool site, I visited that one awhile back. This is a new model than the one I am building, but thanks for the info.
Old 04-24-2011, 01:28 AM
Car5858's Avatar
Little bit of an up date, I started cutting material for the main cross members. Then had a resaw job come in that was a rush.
I did manage to get the rear suspension designed, Tyler will be making the bag assemblies for me, Thanks Tyler.
Here is the layout.
Old 04-24-2011, 12:08 PM
rockNmayhem's Avatar
Carl it looks like you nailed that suspension geometry right away. Renderings look great and I am proud to have some products for you on your truck. It will look awesome when it all comes together. Can't wait to see some more progress on this beast.
~Tyler~
RockSolidCustoms
Old 04-24-2011, 03:21 PM
Car5858's Avatar
Thanks Tyler, I have been in the shop playing with my drill press that I converted into a mill. Milled out the rear cross member. I will post a pic later.
I have to make the air bag mount next before I install the cross member.
Old 04-27-2011, 12:41 AM
Hey Carl that mount and rear frame there looks good already. I have the lower set of your bags done tonight and I will be getting the tops done tommorow and have them ready to go to you by thursday if I can. Hope you're about ready for them.
~Tyler~
RockSolidCustoms
Old 04-27-2011, 09:29 AM
Car5858's Avatar
Thanks Tyler, that will be great. I have 5 more mounts to make for the bags. I haven't started on the front supports so far. I will be back on the build this weekend.
Old 04-29-2011, 11:03 PM
Car5858's Avatar
Made some progress this afternoon, made the axle supports, changed the design a bit so I can mount the shocks inside the frame like the 1:1. I have the front support side frames started but not finished (need to bend them).
Its amazing what you can do with a bandsaw, drill press, and a set of good files.
here is the axle support.
Old 05-03-2011, 07:58 PM
Car5858's Avatar
Made a little more progress this afternoon.
I will be changing out the socket head cap screws for button heads. I need the scoket heads for the crossmember installation.
Attached the rear section frame mounts and axle supports. Used a .125 punch to help align the parts. Worked pretty good.
One thing I do not like is that the aluminum gets marked easily. I will have to disassemble everything and clean the parts up after everything is worked out.
Thanks for looking
File Type: jpg Suspension right side View rear section 640.jpg (49.1 KB, 116 views)
File Type: jpg Suspension Top View rear section 640.jpg (48.8 KB, 83 views)
Old 05-03-2011, 09:03 PM
Progress is lookin good Carl. Your bags should be there shortly so you can have a rolling chassis. Can't wait to see them mounted up on this great frame. Should look right at home.
~Tyler~
RockSolidCustoms
Old 05-03-2011, 09:34 PM
Car5858's Avatar
It will be awhile before I get a rolling chassis. I have to cast the axle housings and the tires. Still waiting on the rims, then I will have to make the drive axles. Not looking foward to that, I also ran out of 2-56 bolts today.
The good news is that exams are over and I get a break for 3 weeks before the next batch of students come in for summer classes.
Old 05-03-2011, 10:20 PM
Looks good car and taking your time is a good thing it will give you time to think about it and get it exactly how you want it.
Travis
Old 05-04-2011, 12:15 AM
Car5858's Avatar
Thanks Travis, although this is my first build, you guy's inspire me to do better.
Thanks for looking
