Old 05-12-2011, 02:41 AM
texken's Avatar
texken texken is offline
texken is on a distinguished road
Default Re: Liebherr LTM 1030-2
More up date.
Received my (2) 1000 RPM motors from China today.
Also had to make my hubs, as no one had any for 4mm shaft,(that I could find).
So will see how they work as soon as I find some way to mount then to Truck.
Any input welcome. Did see some on line, look like a block with hole for motor.
TEXKEN (ken)
Old 05-12-2011, 12:10 PM
JensR JensR is offline
Do you mean 100rpm by any chance?
The hubs look good!
Brass tube with brass collar? Collar drilled and tapped?
Attaching motors:
press into plastic tube
glue into other tube
screw into mounting holed on front surface of motor, angled metal plate
use hose clamps to secure motor on metal/plastic profile
Old 05-12-2011, 12:37 PM
texken's Avatar
Smile Re: Liebherr LTM 1030-2
JensR, Set Screw.
Thank you for the input, on mounting.
Two Motors for $14.98 shipped, they are 1000 RPM's.
They test fun good on 4-AA.
Will see how it goes. LOL
Old 05-20-2011, 05:29 PM
texken's Avatar
Rear Drive
Old 05-23-2011, 12:03 AM
texken's Avatar
Drive Wheels
Old 05-23-2011, 01:54 PM
Looks good!
So you make "only" the front axle steering?
Sorry to repeat myself, but I am slightly concerned about the motor being billed as "1000rpm". That sounds quite high and I would have expected (as I said earlier) 100rpm to be more realistic - but if you have done the tests and it works, that's great!
Also, what scale is this?
The first post says 1:25, but this looks bigger?
Cheers
Jens
Old 05-23-2011, 06:35 PM
texken's Avatar
Well, maybe 100.
Rear drive only.
Will be 1/14 scale. Used info from member to find size.
Thank you for looking.
TEXKEN
Old 05-25-2011, 03:36 PM
texken's Avatar
How have Wheels.
Waiting for steering servo.
Need radio, any good input for a radio to run chassis and Crane with one radio??
TEXKEN
Old 05-25-2011, 08:48 PM
texken's Avatar
Old 05-26-2011, 10:16 AM
Looks good with paint!
I wrote this previously regarding radios:
http://www.rctruckandconstruction.co...5&postcount=49
Old 06-22-2011, 06:58 PM
texken's Avatar
Crane up and running.
Need to get the gray paint.
Now can start on the Crane.
Old 06-22-2011, 08:39 PM
texken's Avatar
Default LTM 1030 UP DATE
Now have working chassis.
Will get the gray paint, then start on Crane.
http://www.youtube.com/watch?v=8GzfuSqA9Jo
TEXKEN
Old 06-24-2011, 01:41 PM
texken's Avatar
Old 06-24-2011, 02:09 PM
This sounds as if you are barely using the throttle?
That crane is going to be fast
Old 06-24-2011, 04:16 PM
texken's Avatar
Yep..... Will need power when Crane is mounted.
Old 06-24-2011, 07:03 PM
Power is proportional to speed times force.
So, for a given power: If it is fast, then it is weak.
I'm a bit worried that you indeed might have the 1000rpm motors, in which case you won't be happy, I fear.
Old 06-24-2011, 11:07 PM
texken's Avatar
Thank you for input.
Well can be changed if needed.
Old 08-04-2011, 01:25 AM
texken's Avatar
Test of Turntable
http://www.youtube.com/watch?v=qpIryYnZUzQ
Old 08-30-2011, 05:12 PM
Seems to run really smoothly!
Old 08-31-2011, 12:25 AM
texken's Avatar
Hi JensR, thank you for the comment.
Should be better with a speed control.
