Old 06-12-2011, 10:23 AM
Default Re: CAT 14M Motor Grader
Not much to report here, just got the wear blades done
Old 06-12-2011, 01:08 PM
That's more than I can report at this time with any progress.
Your wear plates look very nice. One thing,you will need to use countersunk screws on the wear plates.
Old 06-12-2011, 06:40 PM
mack kid mack kid is offline
mack kid is on a distinguished road
Just amazed at this build sets the bar for quaility.
Old 06-24-2011, 05:41 AM
I made the blade tilt cylinder brackets, and the side shift mechanics.
Old 06-24-2011, 09:59 AM
SmallHaul's Avatar
The whole blade assembly looks great, very nice work.
Scott
"No load is too Small"
Old 06-24-2011, 10:23 AM
sneaky-pete's Avatar
Master A-Modeler
That is bad*ss....youve got skills!
Troy
Old 06-24-2011, 11:03 AM
rc_farmer's Avatar
Master Builder
You have MAD-Skilzs, this is awsome!
Giving up is not an option!!!
Rob
Old 06-24-2011, 11:13 AM
cbazq271 cbazq271 is offline
cbazq271 is on a distinguished road
one of the best hand made RC's I hace ever seen.
Old 06-24-2011, 12:13 PM
JensR JensR is offline
That looks great!
Is the outward connection of the side shift is not outwards enough, it looks like you have only relatively little movement to the right?
In the original, the brackets sit much closer to the end of the blade.
Is this a restriction because of the hydraulic cylinder?
Old 06-24-2011, 01:34 PM
Originally Posted by JensR View Post
That looks great!
The movement is actually made by electric motor and spindle, and that restrict the travel. The short travel (35mm both ways) annoys me too, so I´m going to change the spindle to hydraulic cylinder.
Old 06-24-2011, 02:06 PM
Ah yes, that makes sense. Hydraulic will be beneficial there.
Are you going for a rotary feedthrough for the blade tilt and shift?
I use a spindle drive - it works very nicely and I get a lot of travel, but dirt is an issue. I am thinking about converting to a pull-pull winch - not sure, it's just a thought at this time. But for the high quality of your model, I feel that hydraulics is the way to go.
Set with pictures
BTW, could you tell me what diameter tube you used for your blade?
Cheers
Jens
Old 06-24-2011, 03:18 PM
Cheers
Jens
The tubes is diameter 66 mm.
Old 06-26-2011, 08:19 AM
Ok, now I made the hydraulic cylinder for the side shift. It works much better than the earlier spindel , and it now has much more power and travel (50 mm both way).
Only drawback is that I might not be able to route the hoses inside the horizontal tube, and out in the middle I had to take them out straight from the nipples.
There is also a small video clip of the side shift, and if you wonder why there is a bucket in the picture, that´s because I took the hydr. pressure from my excavator
Old 06-26-2011, 09:30 AM
Ken Orme Ken Orme is offline
Ken Orme is on a distinguished road
Hemi1966;
Your machining and photos are excellant. Keep up the good work.
Old 06-26-2011, 08:53 PM
No words to describe the workmanship, fit and finish. Awesome seems inadequate. You made the side-shift cylinder? Would you be willing to share you construction methods, especially what seals/o-rings and how they are arranged on the piston and head.
Thanks!
Old 06-26-2011, 09:00 PM
That is much better on the side shift. How are you going to keep the hoses from twisting when you rotate the blade?
Old 06-26-2011, 09:20 PM
So smooth and quick - wow!
Old 06-27-2011, 01:11 AM
Thanks!
All seals are o-rings. Both piston and rod are sealed with two o-rings. The cylinder tube has threads in both ends, and the end caps are sealed with 3M Hydraulic Sealant HP42.
The most hardest task is to make the o-ring grooves to the cap that seals the piston rod.
My side shift cylinder has 4 mm piston rod, so you need very small tool to cut the o-ring grooves with lathe.
And of course the grooves MUST be in correct size, or they won´t hold the pressure
The picture you see here is not the side shift cylinder, it´s one I made earlier, but it´s made the same way so you get the picture.
Old 06-28-2011, 02:33 PM
What's the tool look like that you cut the inner grooves with in the rod end cap?
Old 06-28-2011, 02:42 PM
I´m using these: http://www.cut-tools.de/mini-tool-tu...ng-p-1842.html
