#81
Thanks for the comments Nathan!
I thought of all the problems and mods that I would have to do to get it in this truck.I will probably add a mfu,and that wont happen if I put in the cat. The fenders are easy to do......just make multiple cuts around the edge,and cut it away from the hood starting at the back all the way up to the light bucket.Then heat the fenders to shape! I will sell you the cat and radiator if you want it!
Troy To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#82
Here are the pics of what he did,.....it can be fixed with some patience!
#83
Ouch! Chip that filler off and it would be ok. But it would probably take as much time as it would take to work the fenders on your other shell that already has the perfectly formed top to the hood. Not a criticism in any way of your brother's efforts - my build has had filler like that applied and removed several times over! Learning as I build. Means it takes twice as long!!
p.s. I spy a unibilt pete taking shape in the background, nice! Your workbench is a regular assembly line!!
Nick My Peterbilt build thread: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#84
Yes I have a pete in the works in the background......between all of my other hobbies! ![]()
#85
Looking real good.
#86
Thanks Mike!
#87
small update!
I got it primed,installed headache rack,and added Brian's pre-cut deck plate! ![]() ![]() I'm not so sure on the rack mount ![]() to come up with something else?
#88
hey troy i like the rack just not the mounts
#89
Was the original mount too high? Maybe just add some diagonal bars like the original setup, maybe that's what's missing from the current mounts. Looks good anyway, deck plate is cool.
#90
This thing is looking awesome so far, nice job.
#91
Thanks guys!
The more I look at it the more I hate the mount......it's gotta go. The stock mount is to high,but I may try something else. ![]()
#92
I am finally getting around to a small update!
I decided to drop the lift axle and shorten the frame,and have been working on my headlamps.I have not had much time lately to work on my trucks,but sometime is better than no time! I have a lot of filling and sanding to do,but thought I would throw some pics in. The car in the background is a hint at what my next project will be ![]() ![]() ![]() ![]()
Troy To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by sneaky-pete; 08-15-2011 at 01:15 PM. |
#93
Looks good Troy!! I really like the lowered look.
Brian |
#94
That Is BADAZZ!! Troy...What kind of design is that getting...I see seminol...hint hint!!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. One Bus Stop Short Of The Short Bus... |
#95
You nailed it!
#96
Thanks Brian!
Your day cab Pete is my inspiration for this build!
#97
Looking really good, Troy. I was happy to see an update to this build. Hoping to see even more, soon! I have no clue what 'seminol' is, but are you building a drag car hauler or something?
Nathan |
#98
Wow! What a beauty. Shortening the frame was a good decision.
Thumbs up! Cheers Pip |
#99
That looks great! Love the way you re-worked the headlight surrounds like the real thing.
#100
Hi just a thought are you going to blend the hood sides to the fender like i have on my kw ? I think that it looks so much better than just leaving it stock ! Super lookin rig i would love to have some of those rims there the dogs dangles lol
Dave |
Thread Tools | |
Display Modes | |
