#81
actually if you added the top hanger to the scale art it would me exactly like the real thing. Just take the one in the picture and turn it upside down part of the upper bracket is there just make it long. Ed
#82
Very nice modified Wedico Peterbild. i milled also the frontaxle by my Scania
![]() I optimised my Osswald Pendulum Spring because of the Frame high. Befor ![]() after ![]() |
#83
Thank you Marcel. My truck also sits a little high in the rear, now that the front end is lowered. I also have the same Osswald rear suspension that you used. Do you have any more photos of how you optimized the rear of your truck?
Nathan |
#84
Hey nate that truck is really coming togather...really like the idea of the rack with the batteries and it looks great ...awsome build ...gona keep my eye on this one
#85
I read all topic it is really perfect truck and very good information source about wedico and osswald frame and chasis operations. Tons of thanks for pictures
CAT: 963 B Scaleart // 345D LME Wedico // CS 563 E Handmade Mercedes Benz: SK 3544 AK 8x8 Premacon // NG 2636 AK 6x6 Wedico Handmade MAN TGS 26.500 6X6 Wedico - Premacon MACK Granite 8x6 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#86
Hi
Sorry for the late Answer. I made new Holder ![]() ![]() ![]() ![]() ![]() |
#87
man the truck so far look`s great, the work you have put in so far is one of if not the best i have seen for some time, remember all good thing take time.
keep up the great work on it cheers paul tiny trucker |
#88
Your perfect scale parts are killing me Nate nice work!
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#89
Paul, actually you were looking at Marcel's handy work there. I cannot take credit for it. I had asked him a question about his rear suspension, and those are his photos, not mine! He's definitely done some great work too. You've seen his thread here - http://rctruckandconstruction.com/showthread.php?t=893 A beautifully modified Wedico chassis too. Quote:
Marcel, thank you very much! I never considered machining a whole new bracket up, as you did. You did a great job with that. I also really, really like that rear cross member you made, for the chassis. That is beautiful. Hope I can also make one for my own truck. Thanks again! Mind if I ask where you got your scale hex hardware?
Nathan |
#90
Nathan very nice machine work. Keep this up and you would have wasted the money you spent to buy the Osswald suspension. Ed
#91
Wow Nate, when you say "slow" you really mean SLOW! lol Just kidding, it looks great, so incredibly realistic!
#92
Any updated on this engineering marvel (atleast in my eyes) What kind of mill are you using, manual or CNC? I really like your drive train setup, if i ever do a daycab pete i think i will be using it.
"My son will have a chocolate milk" -J.P. Next East Coast Minitruckers Meet: Arioch |
#93
Hi Arioch,
Unfortunately, I have no updates to share yet. Not on the truck anyway. I have, however, purchased my own benchtop milling machine now. It's not as big as the Bridgeport I was using, at work, in my free time, but for the smaller sized parts I want, I think (hope) it will be useful. I'm working on getting it all set-up at the moment. I would like to have it running by Jan. 2012. This build might make it back to the main burner soon enough. I was relocated, at work, to a different facility, so I lost access to the Bridgeport mill, and I got tired of waiting for a chance to continue with this build, so I pulled the trigger on my own mini-mill instead. It has proven to be a significant investment, but it should pay for itself, if I can get it all dialed in. Everything I made, was with a manual mill. CNC would be nice, but I'm not ready for that yet. I have found some CNC conversion kits for my new mill. Maybe for the future.
Nathan |
#94
Just read through this thread again for a recap. You got the stance perfect Nathan, looks so much better without all that air between the wheel and the fender on the front. Have you begun to make the steps? Far be it from me to say anything but I can't help but think your styrene prototypes are perhaps a little too wide. From all the pictures I've seen, the steps are not as wide as the doors they sit under. It might just be my eyes though!
Can't wait to see this fully functional, it reminds me of the 1/50 sword heavy haul 379 I have.
Nick My Peterbilt build thread: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#95
Anyway, guys, I have a small update. I am finally able to blow some dust off this old thread and breath some new life back into it. My progress was pretty much stalled, as I needed parts, but had to no way to make them. So I broke down and picked up new benchtop milling machine. This should get me back on track! ![]() http://i4.photobucket.com/albums/y12...millandDRO.jpg The very first part I finished up, for the Wedico, was this new front cross member. I hated the original very much. It's almost impossible to assemble, as you need to bolt the 2mm screws together, with nuts on the back. Problem is the front member is so small and tight, you just can't more then one finger behind it. As much as I've taken this chassis apart, and reassembled it, I figured it was time to improve what I see as a weak and flawed part. ![]() The original is on the table. The replacement, on the chassis. From a stamped piece, to a solid billet aluminum replacement. ![]() I drilled and tapped twenty 2mm blind holes, for all the fixxings, which keeps the inside nice and clean looking. ![]() ![]() ![]() ![]() Bolted the axle back on, this time with no nuts, and it went about 1,000 times easier then before. Because my suspension was dropped, and my hood and cab dropped, my new front cross member will also let me drop my bumper. Just need to shoot some holes through it, and that is the purpose of the lower hanging front face. So things are getting back to business, finally. Now, if I can just keep it up!
Nathan |
#96
wow , Nate ,looks good
#97
Man i want one of those! Nice work Nathan!
Brian RIP FreddyGearDrive 2-12-59/12-19-11 |
#98
Thanks Brian. Means a lot.
Nathan |
#99
I don't machine like some of the other guys here
![]() ![]() ![]() ![]() A/C I'll try to run them this week with rc channel hubs I have to run ( same stock )
#100
Steve, we are all just human beings, prone to make a few mistakes. The path you take, and the stumbles along the way are not nearly as important as the end results. I've seen your projects. You make good stuff. If I could make my own breathers like you do, I would.
By the way, I'm after the 379 style breathers, so no rubber tube holes needed!
Nathan Last edited by Espeefan; 02-19-2012 at 05:32 PM. |
Currently Active Users Viewing This Thread: 18 (0 members and 18 guests) | |
Thread Tools | |
Display Modes | |
