Old 09-14-2012, 11:51 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Default Re: 6 Cylinder Diesel For a D9
A working diesel in 1/5th scale You really are ambitious!! In all of the years that I have been going to the N.A.M.E.S. show in the Detroit area, I have never seen a miniature working diesel. The N.A.M.E.S. show is a model engineering show for working miniatures of all sorts of engines. I am going to be watching this build very closely.
Your drawbar broke! Without knowing how much of a cut you were taking but a Bridgeport mill is not going to handle much of a cut with a 1" or larger end mill for very long unless you are using a roughing end mill.
LYNN
Old 09-15-2012, 09:48 AM
Jared Jared is offline
Here's a 4-cylinder.
http://www.youtube.com/watch?v=E4-fOw6vr34
Old 09-16-2012, 01:27 PM
Speedy Speedy is offline
Speedy is on a distinguished road
will be following closely
Old 09-16-2012, 07:33 PM
hintzconst hintzconst is offline
hintzconst is on a distinguished road
Its been too hot the last couple days to get into the shop and get anything done but sweat. I got the mill fixed and was able to finish roughing out the stock so that I can rough out the block this week. I did, however, get the crankshaft laid out so that is all designed as well as the connecting rods and pistons. So hopefully I'll have a long block in about 2 weeks. The head and overhead cam I still have lots of work to do, but everything is getting easier as we go. One thing I need to figure out is how to evenly heat up since I don't have anything that gets that hot. I was thinking of looking for pottery kilns on craigslist.
@ TC1CAT
As I had mentioned earlier in the thread the reason I wanted to build a fully functioning scale diesel engine was because I had only found 1 on the internet that actually worked, and that was a four cylinder, naturally aspirated.
As for the breaking of the drawbar, one of my employees had stripped 1/2" of the 3/4" of thread that goes into the collet and because I was just straight roughing I was pushing the mill pretty hard. I was taking aprox. .500 x .250 cuts with a 3/4" solid carbide endmill at aprox. 10 ipm feedrate in solid cast iron. The chips were coming right off but the drawbar being already weakened couldn't keep up and the rest of the threads stripped off leaving the collet to spin and bounce.
You can't fix stupid but you can numb it with a 2x4.
Old 09-25-2012, 02:14 PM
tracksntreadslou's Avatar
Very cool build ..Have you seen this one?..Another 4 cyclinder and not sure what its running on.
http://www.youtube.com/watch?v=63Gqe...ure=plpp_video
Old 09-25-2012, 08:50 PM
dabears's Avatar
dabears dabears is offline
Now that one is cool!!
