Old 08-14-2016, 08:16 PM
crusher's Avatar
crusher crusher is offline
crusher is on a distinguished road
Default Need help with fittings please.
I am building a 4 valve block for my excavator, it is almost the same one shown on this site earlier, my problem is the ports to go to the cyls are only about 3/8" apart center to center. I have spent hours on the net trying to come up with push lock fittings ( 1/8 tube into 10/32 thread ) I have purchased two sets of fittings however neither will mount side by side in the manifold. I see parts made by others showing fittings with a knurled pattern on the outside, cannot find them.
Any help would be much appreciated.
Thanks
Terry
Old 08-15-2016, 08:27 AM
Jack3M Jack3M is offline
Jack3M is on a distinguished road
Default Re: Need help with fittings please.
Everything I am aware of is metric
Old 08-15-2016, 10:47 PM
Blender's Avatar
Blender Blender is online now
Have you checked out SMC? I think the push locks are physically larger than barb fittings with a sleeve. A lot of guys here use barb fittings, although in metric.
http://www.smcusa.com/top-navigation...els.aspx/21836
Old 08-16-2016, 02:09 PM
crusher's Avatar
Thanks for your replies, I may have to rethink and go metric with barbs.
Terry
Old 10-29-2016, 04:01 PM
oldguy70 oldguy70 is offline
oldguy70 is on a distinguished road
Crusher
I always use Festo fittings the small series have 4 and 6MM lines the fitting has one end threaded 5mm (I use a 8-32 tape, and 1/8 NPT, the other end is a push in for the tube. Elbows come with a swivel so you can place them beside each other, rated 150PSI but these smaller sizes will take 300PSI as that's what I run my models.
Earl
Old 10-29-2016, 07:49 PM
tracksntreadslou's Avatar
check these out ..they use the 10/32 thread ..they have a great selection and I have bought from they before http://www.clippard.com/products/fitting-push-stainless
these guys have a pretty decent selection as well ..not alot of 10/32 though
http://www.alliedelec.com/pneumatics/fittings/
Old 10-29-2016, 08:53 PM
thebigo thebigo is offline
Beswick is another really good fitting company for standard threads
