Go Back   RC Truck and Construction > RC Truck's Odds and Ends. > Die-Cast Conversions Tech.
Die-Cast Conversions Tech. The tricks of installing drive line and electrical components into die-cast models.
Old 06-24-2014, 12:17 PM
1/50diecast 1/50diecast is offline
1/50diecast is on a distinguished road
Default Re: Komatsu D475A Bulldozer 1/50 diecast
That is awsome! I might end up using that technique to lift a bed of a 1/50 dump truck, when i get around to it.
I did find a gearmotor that is 6mm in dia. and a 7mm tube that the gearmotor will slide into the tube. Then using another 6mm tube that will slide in the 7mm tube that will be attached to a nut thats driven by a screw. All i am doing is waiting for the stuff in the mail.
Old 06-26-2014, 08:14 PM
Here is the motor that will drive my actuator, just waiting on the tubes to put it in.
Old 07-09-2014, 11:28 PM
Needs paint, but this dozer is to small for real hydraulics so here the next best way for a realistic look.
Old 07-09-2014, 11:29 PM
Old 07-09-2014, 11:30 PM
Old 07-09-2014, 11:35 PM
Old 07-09-2014, 11:47 PM
If this is strong enough ill try making a front loader this way.
Old 07-10-2014, 01:06 AM
Wow!
Cheers, Neil.
Old 03-04-2020, 01:32 AM
Ok round two! So had to put off my project for a few years, ok more than a few years. Hey im back at it now. Cool thing is that over time rc equipment and such have gotten smaller! Ive upgraded from a 4 channel to a 6 channel receiver, smaller battery and such plus more. Im still a bit busy in life but im going to start putting in some time and finally finish this little do-da! Really lately been brain storming on how to finish the dozer.
File Type: jpg 20200303_193134.jpg (157 Bytes, 44 views)
Old 03-09-2020, 12:49 AM
Alright got the screw drive actuators glued together... Got to do some touch ups to make it look cleaner.
Old 03-09-2020, 07:02 PM
That is awesome!!! Glad to see you're back at it.
I've been wanting to build something tiny also, i know DasMikro has an 8ch and escs much cheaper than the german ones
https://www.tiny4x4.com/das87/das87-...7-2wd-ifa-w50/
Old 03-09-2020, 11:16 PM
First test of the actuator!
Old 03-09-2020, 11:39 PM
Awesome website, ive been checking out a lot of sites like this one. I do have a HO train set im planning on seting up on day. Ive had it sence i was a small boy. I do want to RC most of it, plus there has been a lot of technology that has came out... Especially because of drones craze
Old 03-10-2020, 12:15 AM
Trying to get a video uploaded, youtube wants money and photobucket sucks
Old 03-12-2020, 12:54 PM
Frizzy, I LOVE this site, thanks for sharing!
https://www.tiny4x4.com/das87/das87-...87-2wd-ifa-w50
Old 03-12-2020, 12:55 PM
This is an awesome project, it's nice to see you're back to work on it once again!
Old 03-14-2020, 08:40 PM
Ok got some work done, there is some more work to be details to do and a lot of wiring.
Old 03-14-2020, 08:44 PM
Got the ripper servo hooked up.
Old 03-14-2020, 08:49 PM
Here i added some brass tubes to slide the tracks to put tension on the tracks.
Old 03-14-2020, 09:25 PM
Light test
