General Discussion A place to post off topic discussions. |
55 turn still too fast!
Hi guys and girl. My current build is employing a 55 turn crawler motor with no reduction. It seems still too fast (did some bench testing with the battery to the motor direct). My last 2 builds used a PMD 4:1 and a RC4WD 4:1. I was told that the 55 turn was the way to go. Now I really don't have any room to put a reduction in this truck. Is there a different (slower) motor that I could get?? Any help is greatly appreciated!!
Thanks! Brian |
Re: 55 turn still too fast!
Hey Brian, did you change the stock pinion to a 6th pinion?
No, I think it is still stock.
First off a smaller pinion such as a 6 tooth will help. I tried a 6 tooth and a 55 but it is still not as slow as a 4:1. Next if it is still to fast you can go to a 65 turn or a 75 turn with the smaller pinion. Are you planning to use an MFU or similar unit in this truck, if so I think you could still get by with an Integy 4:1 which would put the motor up over top of the servos with no modification.
Travis
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 |
Thanks Guys! Where would I find that integy unit at?
Brian |
brian I'd go with the integy box like travis stated ,thet're not expensive , but use a 55t or 65t unless you want it sllloooowwww like my 5900 which is 75t 3.9:1 integy w/stock pinion + tami 3 spd .
You can order it directly from Integy or I know a guy who has a couple. Here is the part # C22726SILVER for some reason the silver one is half the price of the blue one but they are identical other than color. The package says 2.5 ratio but it has a second gear in it for 3.9:1.
Travis
hey guys ,
keep in mind , in case you are using a Tamiya MFU , the better choice is a gear-reduction and using a motor not much slower when like a 35 turn crawler motor , otherwise you are messing up the power-settings of the MFU unit , especially when you drive your truck without a trailer ( power-selector-switch in the 5th wheel ) For the guys been in Indy this year , my yellow Knigh Hauler is equipped with a 35 turn motor and a 5:1 reduction , which seamed to be just the right speed , even when driven in 3rd gear . And I also “timed” the 35 turn motor about 10 degrees fast , means I do have faster speeds in forward as in reverse.
(Wild)-Willy CustomRCmodels |
Thanks guys. I will be using the MFU.
Brian |
Brian,
After seeing and operating Travis' rigs at Indy I'm hooked on the Integy reduction he has mentioned! In fact I ordered 2 off the bay last night... http://www.ebay.com/sch/i.html?_from...All-Categories -Alex
Whatever floats your boat, just as long as it doesn't sink mine... |
i have a 65T and a 6tooth pinion and its still too fast. im saying up for a gear reduction now
Have you guys taken weight into the account? I have both 55 and 65 with six tooth. I am assuming, after you load it with a trailer or other, this should slow it down some more. Front and rear wheels are loaded with lead amounting to approx, 3 to 4lbs.
Dont mess with ma trucks To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
To get a nice operating ( drivable ) truck there is now way around a gear-reduction .
Just lower RPM motors or limiting the power to the motor via endpoint-settings on the transmitters , adding weight and such is just cheating and you want be happy with it . It would be like on a real car or truck in which you are trying to take of in the highest gear with only applying very little throttle . You don’t have power plus you sucking up the fuel . The idea behind gear-reductions is not only the slower more powerful , plus much more efficient ( less current draw from the battery ) driving , but also the braking . We saw this again this year at Indy , driving up and down the bridge , you could tell right away who had gear-reductions in his truck . A higher gear-ratio gives you also better braking . As for the Tamiya drive-train based trucks , I used to use my self-made 55 turn motors ( way before the lathe-motors and crawler motors were available ) in combination with a self-made 3:1 gear-reduction . This resulted in a actual speed-reduction of about 6:1 , since a 55 turn motor creates about ½ the rpm as a stock 27 turn motor ( 8000 rpm vs 15000 rpm ) . This type of reduction was just the right speed for the Tamiya 3 speed based trucks . When Carson introduced there original ( plastic housing ) 4:1 reduction , that alone wasn’t enough , but a good start , even thought a lot of guys used them , some also with the combination of a 55 turn motor which gave you about a 8:1 speed reduction . Back then , together with RIC from PMD , we created the stronger , aluminum casing , modified Carson gear-reduction and I made some changes to the gearing ( additional ball-bearings ) . This GRU is a nice choice if you don’t have the room inside the cab , but room in your frame . Now with the introducing of the Tamiya MFU unit , the idea with the lower rpm motors doesn’t work so well anymore , since the MFU is tailored for a 27 turn motor and if used with a higher turn motor ( lower current draw ) the effects , down/up-shifting , sound-effects , drivability , just don’t work as good . The choice here would be to stick with a 27 turn motor and do the speed reducing via gear-reduction only. Since I never was a friend of these cheap Mabuchi motors , I went with 27turn motors in a modified motor-can ( adjustable brushes / timing and ball-bearings ) , either self-made , by using the guts out of a Mabuchi motor and installed in a modified motor-can or using the Orion 27 turn Rush series motors , which are now hard to come by . Therefore I am using now the 35 turn Integy crawler motors with a 5:1 gear-reduction , which seams to be just the right speed . Besides the ready to install gear-reductions from PMD or RC4WD , there are plenty of options these days to make up your own gear-reductions from air-plane gear-reductions , or gearboxes from crawlers and such . Maybe we should make a “sticky” out of this , since I would have a bunch of info’s to contribute to this subject , including website links , since I have a bunch of these info’s cluttered all over my website and these questions about motor’s and gearing seam to keep popping up regularly.
that would be nice custom, i need a gear reduction but PMD isway too expensive. im picky so i want something that looks good, is strong, and wont kill me in price
I never used these but this might help you out.
http://store.rc4wd.com/search.asp?ke...=18&search.y=9 |
Update! I got the Integy GRU installed. It is a very nice piece and perfect for this application. it is also very affordable! Thanks for the tips!
Brian |
Can we please see it action Brian....Please
As soon as my MFU and radio comes in I'll get a vid up.
Brian |
