Well time for another one of them worthless long and low working show rigs everybody loves to see
![]() So here is the truck I am starting with.. ![]() ![]() Starting with a new frame that is shorter and one that has the ends of the rails tapered down.Now I went a little longer then his real truck but it is the same as my wife's orange truck.. ![]() Going to fast forward here a little you don't need a screw by screw build of a frame and if you do you need to use the manual.. Here is teh frame with the running gear on I have lowered the front 1/4 inch and slid the axle forward also and mounted wedico tires on stock tamiya wheels for the low pro look. Also have on of IH Builders box bumpers mounted up front.. ![]() Next to make some 5 inch long fuel tanks out of PVC Pipe.. ![]() Ends cut out and glued on. ![]() Now if you look I too another thin piece of plastic and cut out a 5/8 inch round piece and then flattened 2 sides so it look like the fuel tank bung that is welded to the tank and then I used a stainless thumb screw for a filler cap. ![]() Little mock up.. ![]() Ok so now body mounted and a set of Brian in PA's pete steps mounted also. ![]() And now for mounting the new tanks. ![]() Now some of you might be saying that way is the tank mounts kind of goofy well I needed the thickness of the mount to raise the sleeper up so they are set in the same spots as the mounting holes for the sleeper.. ![]() ![]() Now on to the body work.. Not to bad of only 6hrs of work on it.. ![]()
Great start there.I think that truck looked bad as a day cab.TC you are full of new tricks,I like the fuel tanks.
ED |
![]() Ok one more step closer to looking like Dave's truck.. I have added the cab skirts to the cab and the sleeper.. Started with a temp-let to get the sized and shape just right.. ![]() And then out of plastic.. ![]() Then the sleeper I should of got step by step picks but it took 2hrs to get the sleeper skirts right with the tanks and all but here are some. I started with plastic angle screwed and glued to the bottom of the sleeper. ![]() Then cut fit remove cut fit remove cut fit remove and so on and son on.. And WA LA! ![]() ![]() ![]() More detail and body work tomorrow ![]()
Nice job TC, I like the trick way you made the fuel cap n bung, it looks pretty close to real pete tank. Who originally put the truck together? Is that the wedico hi top from pmd on a tamiya bunk? Do you have a picture of 1:1 truck to see what your build is based off of?
Here is the 1:1 ![]()
This rig was hot when you first got it. The upgrades will only make it sweeter!
Paul what was the truck before you started to change it ??
Daniel |
Nice work Paul.......the tanks are cool!
![]() Mock-up is fun. The graphics on that 1:1 look like a challenge ![]()
Troy To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Nice work on the tanks, kool idea and executed well... Are you going to paint them?
"If you build it, they will come" East Coast Mini Truckers To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
It was the Blue truck in the first post? Quote:
Paul, Nice fuel tanks, those are spot on man!
"You play meat?" |
Ok little update from late last night.. Did my drive line like I always do nothing really new there. ![]() Also did my little trick and I think others do something similar so it steers alot better. ![]() ![]() ![]() Then i tried to see if i could make my eyes pop out of my head and make a shuttered grill and it just about worked after a hour and a half.. ![]() Used polished stainless for the shutters I still need to clean it all up from my fingers. ![]()
Paul, Grill looks nice as does reat of the truck. ?? for you- what thickness of stainless steel did you use for the louvers in the grill?
LYNN |
Member Of The Central Plains Mini Truckers.. |
Wow that grill is amazing!!! Are the shutter's fixed or do they open and close? Also could we see a pic from the back side of the grill sir?
Mike
Thanks Much driver. Thanks Mike.. They are fixed I have no need for them to move and ill get you a pick later this week so check back..
great work paul - i like those tanks - emphasises the idea of using common materials. your grill looks good too.
chris |
Great Build Paul! The detail that you are putting into it will make a great truck for sure. I like the raised area around the filler cap on the fuel tank, nice attention to detail! The grille came out nice also, its a real pain in the a$$, huh? you've captured the look for sure!
Brian |
Thanks Paul i will be watching and great work on the truck so far!!!
Lookn good paul, Ive always wanted to do a grill like that. Is it going to be painted black like the real truck?
"My son will have a chocolate milk" -J.P. Next East Coast Minitruckers Meet: Arioch |
