Old 06-03-2013, 12:17 PM
pigeonfarmboy's Avatar
Default Re: Komatsu WA500-6 by Fumotec
Looks like she needs some weight for traction. BBs in tires should do the trick. Looks like the tires don't have a problem slipping on the wheels. Are the wheels beadlocks or just glued?
Old 06-03-2013, 01:22 PM
The axles and brushless gear motors look powerful. Thanks for sharing the videos. Haven't seen anyone post videos of this loader working yet.
Old 06-03-2013, 02:35 PM
Arnd Arnd is offline
Arnd is on a distinguished road
Unfortunatly the tires are only glued.
If it would be fixed by beadlock it would be easier to add some weight in it.
Sorry about my German question: what do you mean with BB?
Old 06-03-2013, 07:32 PM
Ball Bearings or Lead Shot
Old 06-03-2013, 08:36 PM
Kaf343's Avatar
Kaf343 Kaf343 is offline
Kaf343 is an unknown quantity at this point
If the tires are the same as the Stahl 922, which I believe they are, there solid tires. So weighting them won't be an option.
Old 06-04-2013, 02:38 AM
The tires are from AFV-Modell => Goodyear 29,5R25 GP-4D
Old 06-05-2013, 06:47 AM
Understand.
I thought about this, disatvantage the noise you have while the wheels are truning.
Water plus antifrize is may be an option.
I will discuss at the weekend with friends. May be they can work out the back end weight from fully brass. At the moment it´s plastic filled with lead shot.
Old 06-07-2013, 09:51 AM
some more pics from the set up.
to fix the fenders on both sides I placed a screw in the back of the front end.
with a smal water-level I could adjust it.
Old 06-14-2013, 02:03 AM
Most holes are drilled, but the winding must be cutted.
I use a old drill chuck to hold the Thread cutter.
Old 07-09-2013, 02:00 AM
The hydraulic parts have just enough space in the frontend.
Old 07-09-2013, 02:06 AM
And the rear end is filled with battery, pump, oil tank and so on.
Old 07-23-2013, 05:39 PM
That interior is much more cramped than I had imagined. I was hoping it'd be more roomy to make maintenance easier.
Old 07-23-2013, 07:02 PM
SmallHaul's Avatar
Very nice running machine, great build!
That Jung pump sure is quite, fast and smooth even running at 18 to 20 bar.. where could that pump be purchased separately? Are you running the pump at 12 volts/3s lipo?
Do you know how much electrical current the pump is drawing with your setup?
Thank You very much for sharing!
Scott
"No load is too Small"
Old 07-23-2013, 08:49 PM
ihbuilder's Avatar
Scott , premacon
Old 07-23-2013, 09:22 PM
SmallHaul's Avatar
Originally Posted by ihbuilder View Post
Scott , premacon
i don't see a belt driven pump on Premacon's web site? Maybe they don't carry that particular pump.
Scott
Old 07-23-2013, 10:39 PM
ihbuilder's Avatar
Ah I was thinking just pump you may have to talk to Frank maker of this machine
http://www.fumotec.de/englisch/index.php
Old 08-01-2013, 06:29 AM
Hi, best thing to contact Frank directly.
The pump is on his side:
Jung Pumpe
I run the Komatsu with 3S 5000mAh Lipo.
My Futaba RC-System is not able to mix to chanels as V.
It would be the best to run the pump smoothly just with small speed and only power up if pressure is needed.
But my FX18-1 can´t do so.
So I have to save my money to buy a RC-System which can do so.
Old 08-01-2013, 09:38 AM
SmallHaul's Avatar
Jung Pumpe
Thank You very much. Interesting/good idea to allow the pump to run slowly when not needed, instead of shutting it off. i'll have to try that on the loader that i am currently working on.
It is disappointing how many radios don't have very many mixes available on them. i prefer 7 mixes.. 3 for hydraulics and 4 for sound. (6 sound mixes for an excavator)
Scott
Old 08-02-2013, 08:51 AM
The power will have a peak starting the engine, so it´s better to run slowly.
Old 08-02-2013, 01:44 PM
MoRockN's Avatar
MoRockN MoRockN is offline
MoRockN is on a distinguished road
Very nice machine! I need to learn how to use these mixes you guys are talking about. I have plenty of radios that can do it, I just can't
If you got it, a Trucker brought it....
