#561
Yeah Rob it was great to chat with you too! Hopefully I can make the drive up there before too long and check out that kitchen you've been using as an excuse not to finish your RC's
#562
#563
#564
Hey Reg, sounds good to me, and no slobbering yet, LOL! (puking oil for the un-initiated)
Cheer's, Neil. |
#565
No doubt about it....it´s a two-stroke diesel!
regards, Frank |
#566
Kerst |
#567
That sounds like a screaming detroit, good find!
#568
Well now that I know it isn't just my ears that think it sounds like a Jimmy I'll share what it is...
It's actually a twist grip engine noise maker thing that my parents bought for me to have on my first bicycle back in the late 70's. I started looking at it a month ago but couldn't figure out how to fit it in anywhere without cutting it. I was worried that if I modified it too much the sound would change loosing it's "Detroitness" but yesterday I felt that I should give it a go. I had to chop and hack quite a bit off of it so I was a little nervous but I think it sounds great! Of course there aren't any fancy air brake sounds or horns but I didn't have to spend an extra dime on it so I'm happy. I used and old gear motor to spin it, made up a simple adapter hub, and drove it off the spare channel on the Sabertooth ESC. ![]() ![]() ![]() ![]() ![]() ![]() Thanks for looking! |
#569
That's what's making the engine sound? Wow!
#570
![]() ![]() ![]() ![]() Reg |
#571
Reg, the sound system is spot on for a Jimmy V12. All you gotta do is figure out how to throw some shifts in there and you got it made.
#572
Wow that sounds great!! I do have to ask if you took a pic of the purring engine sound maker? I new at this but is it possible to hook up to the drive motor with a Parel circuit? Then with each shift it would rev up an idle down right? An as for running at idle tho may need to run an isolated/ dedicated circuit. Nice build!! I plan on reading the whole story tonight.
#573
Thanks John, You probably seen it but I think post 575 shows a picture of the noise maker.
I almost have the lowbed finished. I just need to make up some center caps for the wheels and it's done! I also had to take it for a drive this evening to test out the new tire foams and paint...http://youtu.be/B7A_0q11Z7c ![]() ![]() ![]() ![]() ![]() ![]() |
#574
that sounds cool! definitely a detroit
#575
SWEET
![]() ![]() ![]() Okay check out this link I found. It has all the information you need for your next build ![]() My grandpa ran a line machine that was mounted on a off highway truck so it was a self powered chassis and he could literally "cast" or throw the grapples right onto the log within like 40 yards ![]() ![]() ![]() Last edited by Trucker_Jo; 10-05-2013 at 11:31 PM. |
#576
Thanks guys.
Trucker_Jo, Thanks for the link! I will have to spend some time looking at all the stuff on there. I don't think a line machine will be my next project but it is on the list and not too far down. I spent a while trying to get the sound unit to be less 'idling or pinned'. It's a bit of a challenge because the sound unit motor always takes the same amount of throttle for a given rpm where as the truck always varies based on load. I did manage to improve it slightly and I think I am just going to have to be satisfied with how it works. I need to keep in mind that this was something designed for a small kid and a bicycle, not to replicate the sound of an Off-highway Kenworth. ![]() http://www.youtube.com/watch?v=ep7Ub...tJ-DusnO8Onw7A The onboard shot picks up a lot of background noise from the driveline and also it was quite windy here today. I think if the camera was actually in the cab instead of behind it on the water tank it would sound pretty cool. http://www.youtube.com/watch?v=kCbCD...tJ-DusnO8Onw7A Thanks for looking |
#577
The sound unit sounds great. It is a definate improvement over the first videos.
Now its time to start loading it up real heavy and test those differential gears out with some long steep grades. ![]() ![]() Last edited by FlyingBeagle; 10-08-2013 at 05:32 PM. |
#578
#579
Off-Highway dump truck.
#580
This insane most awesome rig belongs in a museum! I dont have any words to justify the amazing craftsmanship...I am blown away!
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
