#41
Nathan you give new meaning to the word perfectionist.
#42
Thanks for showing the new tranny system. I have one of the transfer cases' in my Studebaker. Only problem I have found with it is its tolerences. Shafts have way too much 'play' in them. Other than that they are very heavy duty like your gear reduction.
Can't wait to see your Pete completed. |
#43
Wow Nathan you still working on this? lol looking good tho, i think both our projects are taking a little to long compared to other one here! That tranny combo looks bullet proof, i really like it.
#44
Thank you Craig. Just trying to build the best truck I can! ![]() Quote:
I was able to machine up a new chassis cross member. Since deciding to revamp the drivetrain of my truck, I was in need of way to mount up the new transmission. I also needed a way to mount my cab, after lowering it for the new stance. This is what I came up with. ![]() ![]() I designed it to fit perfectly between the chassis frame rails. I still need to drill and tap some holes to secure it to the frame rails, but it's a press fit into place and I haven't yet decided it's finally resting place. I may slide it fore or aft, just as soon as I get some mounts made up for the transfer case next. Driveshaft length will determine the final position, but it will be hidden completely by the cab. ![]() And then the transmission and motor mount to the cross member, like so... ![]() ![]() View from the underside... ![]() And one from the side of the chassis. Once the fuel tanks are on, it will be almost impossible to see, except if the truck is upside down. ![]() The transfer case will find it's home just forward of the lift axle. ![]() That's all for now guys. Let me know what you think! ![]()
Nathan |
#45
Nathan,
You never seize to make me feel absolutely stupid in some of my designs. Once again, you have raised the bar. ![]()
Rick.--- I suffer from Wedicosis ------------- My other truck is a Komatsu To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Rogue; 10-23-2010 at 09:57 PM. |
#46
What a very clean and perfect job you do one your parts I am very impressed nice work Nate..
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#47
Nathan that truck is so pretty it's gonna be a shame to paint it!!
Brian |
#48
Great truck Nathan
![]() Travis
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 |
#49
Nathan is your new signature a sign of things to come? Don't take this wrong but I already miss the tractors.
#50
Just mind blowing Nate....A true masterpeice at its best....Great job....
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. One Bus Stop Short Of The Short Bus... |
#51
Great job.I am enjoying every step.You are the man.
![]() Ed |
#52
WOW.. Great job Nathan.. The one problem I have with seeing artisans like you at work is it makes me feel like my stuff is crap!!!
Fortunately I thrive on that stuff... There is no such word as "Good Enough" in my book.. Again great job. Keep going.. it makes my build better... -Mike
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Mike "DREAMWEAVER" Johnson To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. RIP FreddyGearDrive 2-12-59/12-19-11 Rims and Tanks by ihbuilder / Grill and Visor by Brian in PA / Mirrors, Front and Rear Bumper, Back of Cab Lights, and Steering Arms by tc1cat / Fenders by Stylin n Profilin / Frame Rails by The Late Freddy Gear Drive |
#53
I appreciate that Ed! Thanks. Quote:
Nathan |
#54
Hi guys, I've been on a bit of a roll lately, and I whipped up some transfer case mounts for the Wedico! Now I have a nice way to mount up the t-case and I can continue working on the rest of the driveline. There isn't much left to do, but get the driveshaft lengths figured out, and figure out the permanent mounting location of the trans.
Here is a picture of the transfer case and it's new mounts. ![]() I'm still sliding things around in the chassis, but the transfer case is practically guarenteed to be sitting where it is in these pictures. I just need to drill some holes through the frame rails and bolt her up! ![]() ![]() ![]() ![]() ![]() Things are starting to come together, and space is getting tight! I still need a way to operate my lift axle and I was thinking of using a servo, but it will take a little creativity to fit one in now, and it will most likely require some more custom machined parts! That's all for now. Thanks for looking.
Nathan Last edited by Espeefan; 10-26-2010 at 02:37 PM. |
#55
Looking good!
Jeff |
#56
Nice and neat mounting!
#57
Nathan that is some very nice work. Ed
#58
very nice work cant wait to see it done!!!
LARRY,the doggy dish dealer |
#59
Very nice build. I'm not in to trucks just yet but really enjoyed all of your excellent closeups. This gives me more insight into what I'd be up against if I were to build one of these trucks. Do you have the overall weight yet? Or did I miss that in all the replies?
#60
I like how you whip thing up. Nice work Nathan.
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
