#61
Thanks Rodney! That's the plan.
I hope to have some time tomorrow to work, and then I can finally get it all together! ![]()
-Chris To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#62
May have to get you to make me a set of those fenders for my build.
#63
![]() I wanted to show that I am still working on this build, in bursts. First I hit the fenders with some putty and primer: ![]() ![]() I also started working with some brass! I'm planning on a dump system similar to Lostinoz's Scania dump truck: http://www.rctruckandconstruction.co...ead.php?t=6152 I will try a different hinge, and mounting system, but his build inspired this brass structure. ![]() ![]() ![]() Not the finest, but the fact that it fit on the frame perfectly at both ends blew me away. Measured 64 mm, soldered, and measured 62 mm. Magic! ![]() I have another shipment of brass coming soon, and only a few scars! ![]() I also relocated that On/Off switch plate, because of all the empty screw-holes! I hope it can fit with the brass structure at the end. I'm thinking a screw-drive for this one, but that will be a whole other matter entirely. I'm going to go slap some mud flaps on this thing! ![]() Let me know what you think, and any brass-working tips are appreciated! ![]()
#64
That's cool.You fab them up I'll finish them off.I'm a painter/bodyman.I can make anything look good.lol.
#65
Your brass work looks really nice! So no dump trailer, huh? Just a dump truck? Maybe a transfer dump, with a pup trailer at least? Ha ha. Any kind of trailer...?
Nathan |
#66
![]() ![]() ![]() Quote:
![]() Man, you and that dump trailer... ![]() ![]() I was debating one or the other, and if this dump box turns out nicely, then I may attempt a similar dump trailer. Transfer dump would be cool too, but I'd need to build two of these brass thingies! ![]() How about: I'll look into making a dump trailer, as well. You can hold me to that! ![]() No real progress, although I picked up some brass tube for the hinge. I'm not entirely sure about my plan for that. I did put the mudflaps on, and they actually add a lot to a chassis this empty. If my brass order doesn't arrive tomorrow, it'll be pipe-cutting and body work, if it does, then I will hold off on the filler. I also have a few concerns I'd like to share with you guys: Power options for the screw-drive? Lifting arm positioning? (Whether the arm will be pushed towards the rear to lift the box, or pulled towards the front to lift the box.) I'm thinking about mounting the motor between the frame rails, but attaching it to the brass frame, so that it can be easily removed. Thanks for looking! Let me know your thoughts on those things. ![]()
#67
If you need my help don't hesitate to ask.
#68
Thanks Rodney! If you see me do something strange, feel free to point it out!
![]() Well, I finally put the two pieces together! I just need to see how it fits on the chassis, in case I need to adjust it. I think it looks pretty good, if it fits! ![]() Here are the pics: ![]() ![]() ![]() I drew up a grille, got it printed, and it is on the way! Only it's coming from Belgium! ![]() ![]() The grille should arrive in a month or so, but I have plenty of work to do before then. I hope to start chopping the pipe up tomorrow! I also need to braze up a hinge! Let me know what you think! ![]()
#69
#70
It looks great. It's lines up well & is well proportioned.
Your dedication is paying off. Take your time and don't rush now. - RCT
WCMT Director - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "Keep the Shiny-side Up, the Dirty-side Down & Keep 'er to the Line." |
#71
hope i not too late to comment but great job, inspired me alot, i like all the ideas on here hope to see more wonderfull pics, and the trailer to dont forget lol
#72
#73
My 3D-printed grille just came in, although it is a little small:
![]() So, while I work out a new one with the company, I will be trying to finish up the rest of the body. The fenders are not straight enough, and coming off. The headlight boxes need sanded and puttied, and then a new coat of primer, and it should be paint time! ![]() That is very hopeful; I'll see what I can pull off. ![]() Let me know how the mini-grille looks! ![]()
#74
Mini grill is pretty sweet! 3d printing is an incredible thing
"My son will have a chocolate milk" -J.P. Next East Coast Minitruckers Meet: Arioch |
#75
Nice to have you back, Arioch.
I've since printed another but it was in the wrong material, and was a little short. Third round will be coming down the pipes soon, and tomorrow I'll get to some bodywork and maybe even the final coat of primer!
#76
Very nice work Chris..
