Old 06-07-2014, 04:54 PM
Default Re: I need radio help please!
That's great news, Mario!
Yes, you definitely can adjust the EPA for the throttle hold channel to stop your pump from running in reverse, when you flip the toggle switch the 'off' position. Just go under your EPA menu, scroll till you find channel 5, and dial back the EPA from 100% to zero, in the proper direction. Proper direction being you adjusting the EPA for the toggle switch, while it's in the 'off' position. This will effectively give your pump ESC a neutral signal when you flip it to the 'off' position. In the 'on' position the signal will tell the ESC to run 100%.
You got it! Definitely on the right track.
