Old 12-08-2014, 10:36 PM
Supermario's Avatar
Default Re: S&M construction open for bizz nizz!
Will you be able to make two? Innie and an outtie?
I was hoping to get a Innie but the valve stem is smack dab in the center line going to try and remove the stem and salvage that band of rubber.
Originally Posted by Mikem View Post
How are u going to cut it . How about inflating it and marking it out . Just a thought . Mike
The way I see it Mike, if I can't cut a straight line, maybe the fact I'm dealing with a circle will work to my benefit !
I thought about inflating , laying on the floor and make a jig for a marker to roll along the floor around the circumference but.... Too complex! Keep it simple right?
As Joe mentioned, there are clear mold lines in the rubber I can follow. First cut will be extra wide and outside those lines, more belt than I need. Once I get rid of the excess and the belt is easier to work with, I can map out my final cut lines.
That's what I'm thinking anyway. Definitely open to ideas and suggestions for making a nice simple , straight cut.
