Old 12-14-2014, 12:58 PM
rctrucker2's Avatar
rctrucker2 rctrucker2 is offline
rctrucker2 is on a distinguished road
Default Re: Trailer light DIN plug at tractor
Problem solved thanks to Ryman here on our forum. Riley had the perfect solution and it works great. We started with a piece of heavy plastic cut to form around the Tamiya aluminum plate that would bridge the gap in the frame. Then marked the holes for the DIN plug and drilled the plastic. Then Riley used aluminum diamond plate from RC4WD to make a cover that would cover both the Tamiya aluminum plate and the plastic piece for a very nicely finished product. It not only looks good but also works great. Because of the tight fit between the servo and the frame cross member, some material had to be removed from the cross member to allow for clearance. A big thank you out to Riley for his help on this. Pictures attached.
[/IMG]
