Old 03-17-2015, 09:50 PM
osikasculptor osikasculptor is offline
osikasculptor is on a distinguished road
Default 4200 xl pressure dial/4th servo
I just noticed my replacement radio had the last aux channel for 4th valve
on the gear switch instead of Pit trim dial. By putting it on the pit trim; you can turn off the mix toggle and use the dial to manually adjust pressure from the radio as an option.
