Old 02-24-2016, 09:41 PM
Prop Shaft's Avatar
Default Re: Capo 1:8 Jeep CD15823
Found some time to work on the wiring a bit.
Finished up the front lights. Hi/Lo beams, parking lights, and turn signals. The turn signal lights will only function as hazard lights as im not really that fond of turn signals tied to the steering.
If anyone is wondering this is the light controller I'm using from Al. (Heyok)
Finished up the wiring behind the dash. I hid what I could here. The only components left to hide are the rx and esc. And I have some plans to hide them in the engine bay.
I also saw it fit to cover the back side of the dash panel with some electrical tape. The light from the led's in the dash was bleeding into the engine bay and through the vents in the cowl.
