Re: Chassis rail sizes
The Tamiya rails section outer dimensions are, 21mm high, 7mm width over the flanges, 1.5 mm thick web/flanges. The inner corners are sharp, no visible radius. some after marked profiles have a radius. I more like the original Tamiya section, but aftermarket profiles will do, even if there should be a small inner radius.
I know at least of RigidRC.com online that offer similar to original Tamiya section rails, no holes, up to 1 meter lengths.
