Old 04-14-2016, 11:47 PM
JamesBC JamesBC is offline
JamesBC is on a distinguished road
Default Re: homemade actuator
I don't believe that ESC has reverse in it, which you would need. The use of a servo control board can be done but it needs the pot replaced with correct resistors and even that sometimes is hard to get it to zero out.
If you only need to switch the power on for one direction and then power on for reverse, simple Pololu RC Switches can be used.
Jim
