Old 08-07-2016, 06:38 PM
Default The two brothers
I'm going to add the project I paused for the torpedo and the 1600 4x4. I called the project the 2 brothers. Becase they are build side by side. Both Are DAF CF euro 6. Both are on Small wheels and tires. Both build as cheap as possible. Both build for vehicle transport. Why I didn't name the project "the twins" one is going to be build as a 8-car carrier. The classic way a truck with a cut roofline on the sleepercab. And a 2 axle trailer. The other one is going to Be build as An truck carrier in the "De Rooy" style again a truck with trailer. It Will Have a daycab with topsleeper and a dropped chassis on the truck and a Special designer trailer. The trucks Will Be build with pictures from the internet a only sourse of informatie. In real Life the de Rooy doesn't Combine the truck I'm Building becase the truck Will Have 3 axles and the trailer as well I haven't seen that been done. A 5 axle combinatie is the standard as I can belive the pictures I found on the internet
Also modeltrucks and modelcars don't scale Down exactly so I'm Building the trucks to fit the load. Not Building it to fit anything. That saves me soms options the trucks Have to Have.
Then Building cheap. I think I don't need to say how I build the cabs. Those Small tires and wheels Pose a Different problem. These I need to make myselfe.
The decks for the trucks Are going to Be Made Out of airgrills I found in the dumpster at work. They wore original planed to Be used in a Different project by one of my clubmembers. But Life truew An onther Challenger in his path. And He won't Be needing these airgrills anymore sadly to say.
I'll get some pictures in next post. First of the combinaties it are supposed to Be. Than of the build op till now. As I sayed the project is paused for the other 2 trucks.
Grtz Petervr
