Old 01-24-2017, 12:22 PM
scottyk scottyk is offline
Default Re: How To Custom Drive Shaft
So are you guys drilling a hole thru the steel shaft and using a traxxas pin instead of a set screw? I just cant picture a plastic driveshaft yoke being strong enough to tighten a set screw against the flat on the steel shaft, steel shaft being the pinion bearing or transmission output.
